DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Creda 950 DL Electric Shower Overheating
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
cjb121
from United Kingdom
PostPosted: Fri Jan 01, 2010 6:13 pm Reply with quote
I have just replaced an old Triton Opal 9.5kw shower which kept going cold after use... it didn't have an overheat indicator.
As it was at least 6yrs old I decided to replace it and chose a Creda 950 DL from Argos. It seemed to have the basic requirement of a proper start/stop button and separate heat and flow controls... and Creda is a well known name innit !!
So, after sweating for nearly 2 days making the existing plumbing and electrics fit ( this has to be the worst designed unit for making connections) I finally switched on ........!!!!
The unit gets hot as expected, BUT... when it is turned off the water flow stops immediately ( rather than the normal 2-3 secs running on) and then a click can be heard. If the unit is then turned back on, the overheat light is lit and it only runs cold.
By turning it off and on again the unit then runs as normal, but the sequence then repeats after each switch off.
It happens on both Med flow and High flow, with heat setting at moderate.
I have tried it with my original hose and shower head, as well as the new hose and head.. exactly ther same result.
Checking the user manual it seems to suggest I might have low water pressure, but the cold water taps seem pretty fast and the washing machine/ dishwasher are OK.
The only doubt in my mind is that we had a water meter fitted some months ago... I am wondering if the pressure was turned down or I have leak in the supply.
I shall contact Creda after the bank holiday but...Any thoughts please ??
Back to top
 Alert Moderators
cjb121
from United Kingdom
PostPosted: Mon Jan 04, 2010 9:08 pm Reply with quote
update.
Spoke to Creda help desk.. who weren't.
They say the shower is not designed to have a phased shutdown and I must have low water pressure.
I can't believe any shower would stop immediately without overheating. Their only other helpful comment was to do what I was doing and switch to cold before turning off.
Fantastic bargain this was.. not.
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Mon Jan 04, 2010 11:05 pm Reply with quote
cjb121 wrote:
update.
very few showers have phased shut down only the descent showers.
if you had low water pressure you wouldn't get any heat as the pressure switch wouldn't be activated at low pressure.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Creda Aqua Wave 8.5kw Electric Shower Problems 9 5980 Thu Feb 11, 2010 11:14 am
CREDA Electric 9.5kw Shower 5 640 Sun May 18, 2008 6:03 pm
Creda 850DL Shower loss of heat - Mid Temp Led has gone out 11 780 Sat Jan 12, 2013 3:31 pm
Red hot water from Creda shower 2 660 Thu Nov 12, 2009 3:24 pm
Creda model 7961C 5 220 Sat Sep 19, 2009 6:21 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
