hello,
the central heating in my house has never been 100% Some radiators work fine, some 50/50, and one not at all.
last summer i decided to sort out all the problems and changed the ones that wernt working, thermoset valves, and took off a few and flushed them out. when i put everything back together and filled the system up again, most were working well.
recently one radiator has needed regular bleeding, thats twice a day and there will be a lot of air in it.
i the air must be coming in from somewhere but i cant figure out where. ive also got a problem with my hot water tank. i know theres hot water there but when i touch it the hot water pipe is cold/lukewarm. then i run the tap, hear a gurgling and pipes expanding, and then the pipe is hot.
firstly are the 2 things linked?
how do i even start investigating this?
thanks
thanks
