DIYnot
Local | Network
   DIYnot > Forums
Local | Network
help: Ford Escort 1995 Idle Control Valve
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
IronNaz
from United Kingdom
Thanked: 12 times
PostPosted: Sat Jan 02, 2010 12:01 pm Reply with quote
Hi
I need some help on locating my idle control valve on my 1995 ford escort. The reason is my car has recently been stalling when I stop at lights, at junctions and when i suddenly break. The car is also mifiring. So as I accelerate, the car shakes. I've checked the HT leads, changed spark plugs and no difference. I've been advised it may be the ICV which needs cleaning, however i cannot locate it.
I've had a look but cannot determine where it is. I have taken a photo of the only thing i can see which resembles the ICV's i've seen online. Is this the ICV on a 1995 ford escort lx?
[/img]
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 422 times
PostPosted: Sat Jan 02, 2010 4:45 pm Reply with quote
The item in the top picture looks like the Idle Air Control valve, worth a clean out. Also check for any other signs of leakage on the manifold.
Back to top
 Alert Moderators
IronNaz
from United Kingdom
Thanked: 12 times
PostPosted: Sat Jan 02, 2010 6:42 pm Reply with quote
thanks, will give it a clean.
Not to sure where/what the manifold is, i'm a complete novice to cars. Always taken it to the garage but with money getting tight these days i've decided to start doing things myself!
Back to top
 Alert Moderators
ch427
from United Kingdom
Thanked: 232 times
PostPosted: Sun Jan 03, 2010 11:26 am Reply with quote
The inlet manifold is the part in the photo with efi on it which is where the idle valve is usually situated. Start with cleaning that but i would think the misfiring is another problem
you can also clean the throttle body out with the carb cleaner which may help, if you remove the black plastic ducting on the inlet manifold you will see it
coolant temperature sensor is worth changing too
Back to top
 Alert Moderators
bongos
from United Kingdom
Thanked: 78 times
PostPosted: Sun Jan 03, 2010 4:26 pm Reply with quote
Could the misfiring be down to a faulty ignition coil? My '99 Golf exhibited the same symptoms and the cause was two faulty coils.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
idle valve control 2 760 Tue Oct 09, 2007 8:01 am
ford ka help needed changing heater control valve 2 21820 Sat Oct 01, 2005 3:27 pm
KA sport overheating! How to test heater control valve? 6 1120 Wed Feb 24, 2010 11:47 am
Ford escort 1995 wont start 3 140 Mon Dec 20, 2010 9:36 am
1995 ford escort brake pipes 2 460 Fri May 18, 2007 4:42 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
