DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ford Focus 03 No screen washer
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
Diyisfun
from United Kingdom
Thanked: 209 times
PostPosted: Sat Jan 02, 2010 6:25 pm Reply with quote
Focus 03, the pump is not going when I try to wash front or rear.
Is there 1 or 2 pumps, I would guess at 2 & on the same fuse. I have the manual the only mention of washers is for headlights & that fuse is not in the fuse box.
Have done plenty of searching cant find any help.
So is it 2 pumps on a common fuse? where is the fuse?
Ta for reading
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2459 times
PostPosted: Sat Jan 02, 2010 6:53 pm Reply with quote
Usually only one pump is used - it spins one way for the front wash and the other way for the rear.
As neither of yours seems to be working, locate the pump in the bottom of the washer bottle, disconnect the lead from it and see if 12v is there when the column switch is pressed.
If 12v is there, this means that the pump is goosed
If 12v is not there, often its the column switch at fault.
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 209 times
PostPosted: Sat Jan 02, 2010 8:14 pm Reply with quote
Thanks 4 that, the pump is an ar** to get at, thats why I wanted to check the fuse first.
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2459 times
PostPosted: Sat Jan 02, 2010 8:17 pm Reply with quote
They sure are - and ice often causes the pipes to pop off the pump too. icon_confused.gif
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 415 times
PostPosted: Sat Jan 02, 2010 9:06 pm Reply with quote
The washer motor should be from the 20amp fuse 94 which is located in the fuse box behind the glove box, however if this pops I'd expect to see more stop working such as the wipers.
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 209 times
PostPosted: Mon Jan 04, 2010 8:10 am Reply with quote
Have been told prob on same fuse as wipers, it will have to wait till warmer weather, dont just the car much, so not to much of a problem
Back to top
 Alert Moderators
Johnny8888jazz
from United Kingdom
PostPosted: Tue Jan 11, 2011 11:49 pm Reply with quote
I have the same problem; wipers working but washer pump not spinning. Fuse not listed in handbook.
Could it still be frozen? I've done 250 miles in it today.
Is there a way to check (sticking something in through the filler) to see if it is frozen or not or is there a filter in the way perhaps? 12 months ago I had the washer bottle out and don't want to have to do it again if I can help it.
John
Back to top
 Alert Moderators
jetex
from United Kingdom
Thanked: 22 times
PostPosted: Wed Jan 12, 2011 12:36 am Reply with quote
The washer fuse is behind the glove box. It's the most awkward one to get to, in the top left hand corner.
Back to top
The following user says thank you to jetex for this useful post:
Johnny8888jazz (12 Jan 2011)
 Alert Moderators
blub
from United Kingdom
PostPosted: Sat May 14, 2011 9:58 am Reply with quote
I found the motor to be working when 12v battery applied to it separately.
The spade contacts were the problem- so a quick clean solved it. It's not difficult getting to the pump- jack up the car on nearside and unscrew right hand plastic wheel arch cover. Peel back, unscrew bottom washer bottle screw and swing bottle & pump to reach. Shouldn't take more than 1/2 hour.
Back to top
 Alert Moderators
kelly1976
from United Kingdom
PostPosted: Fri Jul 19, 2013 8:14 am Reply with quote
Hi there, im having a similar problem with my '03 plate focus. The rear is working however the water is falling inside the car onto my parcel shelf! Am guessing this is due to a pipe coming off.
The front ones dont work at all, the wipers work but no wash, my husband took a quick look at it and he says that when i press the button the pump isnt spinning.
Would the 2 things be related or is it just a coincidence? Or has my pump motor gone up the creek??
Any advice greatly appreciated, car is due for an MOT in a few weeks so would like to get this fixed as cheaply as possible before then!
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2459 times
PostPosted: Fri Jul 19, 2013 8:21 am Reply with quote
At the back of the car, your diagnosis is absolutely correct - the water pipe has blown off the nozzle.....this generally happens when the nozzle is frozen in winter.
You'll have to remove the tail gate trim to access the rear of the nozzle.
As for the front, there's a higher risk of pump failure rather than the column switch, so chance replacing that unless you have access to a test meter.
The pump plugs into the bottom of the washer bottle, and its available from a motor factors rather than Ford.
The washer needs to work for the MOT!
Back to top
 Alert Moderators
kelly1976
from United Kingdom
PostPosted: Fri Jul 19, 2013 8:38 am Reply with quote
Thank you for your quick response. Its typical, i think my car knows its going in for its MOT so has decided to be awkward!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
Screen Washer Pump 2 840 Sun Dec 09, 2007 12:32 pm
Fiesta Encore 1.3 1997 Screen Washer Problem 2 740 Thu Nov 01, 2007 7:20 pm
Pugeot 106 screen washer? 4 120 Wed May 18, 2011 10:03 am
Screen washer jets not working 4 382 Wed Dec 01, 2010 10:39 am
mk5 ford fiesta - cleaning jet/screen wash filter 7 260 Mon Dec 20, 2010 7:40 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
