DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Laying bricks in cold weather
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
elsmore1
from United Kingdom
Thanked: 1 time
PostPosted: Sun Jan 03, 2010 10:41 pm Reply with quote
Hi All,
I am building a conservatory base and have build the strip footing before xmas and have a hardcore centre and need to build a 3 course wall and then fill with concrete.
I am concerned about the cold weather I laid the concrete ok and it seems to be solid I covered with hessain and it did not frost until 2nd 3rd night so it was quite set and I could see no frost on it at all. I laid a few bricks about 16 between 10 and 1 o'clock on new years day I think and it was sunny but cold it frosted at night but again I covered with hessain, but the mortar is still a bit soft amnd I can scrape with ny fingernails!
The bricks wont move when I try to move them and did step on one by mistake but i am concerend that it should be solid by the 3rd day.
It did not have any frost on it at all but it has been cold and no sunshine at back of house. I mixed 4 sand to 1 cement and used a plasticiser from builders maerchants. Will I need to remove and re do or leave longer, also not sure when I will ever be able to build again until March perhaps, or maybe just avoid the frost. i did cover the bricks as soon as i laid them to protect them.
Many Thanks for advice
Back to top
 Alert Moderators
jm2000
from United Kingdom
Thanked: 6 times
PostPosted: Mon Jan 04, 2010 6:50 am Reply with quote
As long as you put the cement in it should go off. Dont lay in the frost wait until later in the day. and then cover very well.
It may take longer to go off...but it will do.
Back to top
 Alert Moderators
Chukka63
from United Kingdom
Thanked: 81 times
PostPosted: Mon Jan 04, 2010 9:02 am Reply with quote
Its suppose to be 3 and rising before laying bricks,however plenty of people do but you must prevent the frost getting into the mortar well after youve laid them.Not sure how hard the frosts have been on the south coast but its been quite severe here so because of that i wouldnt lay bricks at the moment.Your bricks may appear fine for several days/weeks if we keep getting frosts and one day you may find the frost has hit them harder than you were aware.
Back to top
 Alert Moderators
PrenticeBoyofDerry
from United Kingdom
Thanked: 1931 times
PostPosted: Mon Jan 04, 2010 12:05 pm Reply with quote
Ideally brick laying should not be done if the temp is 3 degrees c or below, 4 degrees c and rising is the guidelines.
So wait until you have them temps or you could well be wasting your time, then wrap the wall up.
It will also help if you ad plasticisers and frost prevention admixtures.
Back to top
 Alert Moderators
WabbitPoo
from United Kingdom
Thanked: 120 times
PostPosted: Mon Jan 04, 2010 6:36 pm Reply with quote
It would also help if you used some punctuation in your text - I gave up reading, if I'm honest.
Back to top
 Alert Moderators
elsmore1
from United Kingdom
Thanked: 1 time
PostPosted: Mon Jan 04, 2010 10:28 pm Reply with quote
thank you all for the replies, the mortar is quite hard now But I will leave until temps go up a bit. sorry about puntuation I wrote this a bit hurried and wrote too much also.
the hessian has protected bricks from frost as I have checked each day.
regards
Back to top
 Alert Moderators
r896neo
from United Kingdom
Thanked: 561 times
PostPosted: Mon Jan 04, 2010 10:32 pm Reply with quote
Does no one here use rapid-hardener/frostproofer in mortar? Just curious really for anyones experience with it?
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1324 times
PostPosted: Tue Jan 05, 2010 9:19 am Reply with quote
I am of the opinion that cement needs a certain amount of time to cure to reach peak hardness and durability. If you force this process with chemicals then i think there is a price to pay.
I may be wrong......
Back to top
 Alert Moderators
Chukka63
from United Kingdom
Thanked: 81 times
PostPosted: Tue Jan 05, 2010 10:11 am Reply with quote
frost proofer is frost proofer not frost preventer.used it in the past and you still need to cover the wall.its not a miracle cure im afraid.
we were forced to lay bricks ona site years ago when we were on the books.we froze our armpits off.a few daysweeks later they crumbled to nothing.that will teach the dimwit we thought.
sit indoors in the warm on the pooter till the slightly warmer weather.
Back to top
 Alert Moderators
r896neo
from United Kingdom
Thanked: 561 times
PostPosted: Tue Jan 05, 2010 10:29 am Reply with quote
i realise it is a compromise but how do they ever build in the alps or other places with most of the year around our current temp.
I know they probably don't build masonary for 3/4 months of the year when its too bad but as with so many things when you are used to it, its probably not such a big deal? I can sort of imagine guys building there reading this and laughing ... oh those stupid english pigs ... haw he haw.... fire in another bucket of cemento rapido and pass me those frogs legs.....
Back to top
 Alert Moderators
heliart
from United Kingdom
PostPosted: Sun Mar 07, 2010 10:30 pm Reply with quote
I've had good success using Cementone concentrated frost proofer.
Used this for a lot of post setting in January when it was very cold, and been using it this week for building a block wall.
Sure, I always cover the work before the sun goes down, using old blankets etc.
Back to top
 Alert Moderators
mointainwalker
from France
Thanked: 200 times
PostPosted: Sun Mar 07, 2010 10:59 pm Reply with quote
Here in the French Alps there is no special technique except ......................... planning.
Depending on the altitude, groundworks can usually start in March/April and concrete pouring in April/ May.
Contrary to what you might think, air temperatures of 15 C- 20 C will be normal in April, although I've never tried to measure soil temperature.
So basically it's necessary to either have
a) a raw-shell or
b) roof and windows minimum by November
and if b) then carry on until bad weather forces a retreat.
By the way, the rest of the year is usually very agreeable with temps of 18C - 25 C and usually lots of sunshine so very agreeable for building and eating steak with a nice red ( eating frog's legs very bad for the environment you see ! )
Back to top
 Alert Moderators
r896neo
from United Kingdom
Thanked: 561 times
PostPosted: Mon Mar 08, 2010 11:20 am Reply with quote
Thanks mountain i was still interested!
I worked with a guy who built for a few years in andorra and he said they threw the stuff in liberally, he's pretty old though and a former english teacher, so prone to slight embelishment
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Repairing concrete steps in cold weather? 2 820 Sun Feb 17, 2008 10:57 pm
What min temp for cementing in cold weather? 6 2280 Mon Nov 01, 2010 8:36 pm
building inspector control - concrete cold weather 6 100 Mon Jan 20, 2014 12:14 pm
Exterior Render - cold weather 5 3460 Thu Nov 09, 2006 7:08 pm
weather for laying block paving 5 180 Wed Jan 01, 2014 1:09 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
