Kitchen Downlights
Status
Not open for further replies.
8 Feb 2005
Cheshire
Just looking for some alternative advice on installing 8 downlighters 50W in the kitchen. The sparky i'm using has suggested using LV (£15.00 each), but i've been made aware of connecting to the mains. Which way should i go? :confused:
Do you really need 400W of lighting in a kitchen? That sounds an awful lot of energy (think of the Ozone layer! :) )
If you really need 8 areas of light, have you considered the 20W versions? Eight of these still cost three times as much to run as a single 5' fluorescent, but it's 40% of using 50W and you'll save money on the the transformer(s) too.
Cheers,
Howard
some would say there are reliability issues with mains rated over 12volt ones. I personally think mains rated are perfectly ok if used properly ie to stop the high inrush current when cold which is one of the main reasons for blowing them, I use soft start controllers which work very well and seem to stop all the reliability issues.
we have 9 in our kitchen, but its a very large kitchen with a high ceiling
have fitted some in a bed room just by using loads of 20w, would say its the way to go!
low volt v mains
almost three time the lumen output per watt
longer life
cheaper lamp cost
One critical point which ever you choose ( buy branded products especially lamps)
Delman, sorry to but in,
__________________
lynda, moderator
mondial, please see forum rule 17 & 20 the post you have hi jacked was made in 2005
Status
