PCB fault on baxi 105e
17 Dec 2007
Nottinghamshire
Fitted a diverter valve on a 105e today. After fitting I got a 'pump fault low pressure' flashing neon.
The pump runs, and there is enough pressure, so i'm thinking it may be a PCB fault. Anyone else had this problem?
Thanks.
Perfectly ok before...... Water into the board very easily done on a 105
Does this look for a change in pressure when the pump starts?
Like the Vaillants?
Yes I was thinking it was a bit of water into the PCB......another trip to parts centre then!
