DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Condensation Steel shed roof insulate?
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Author Message
Caroline82
from United Kingdom
PostPosted: Thu Jan 07, 2010 3:56 pm Reply with quote
Hello
I'm hoping someone can help me, I have a shed 12 x 14ft to house my rabbits it has a steel profile roof and its causing me a few problems in regards to condensation. I woundered if i wedged between the rafters (touching the roof) 75mm of polystyrene boards would this stop the problem? (i've used foam filler to fill the gaps from teh outside) i'm also thinking about insulating the whole shed like this? Any help would be great,
Caroline x
Back to top
 Alert Moderators
coolcatkelso
from United Kingdom
Thanked: 2 times
PostPosted: Thu Jan 07, 2010 5:08 pm Reply with quote
Hi there Caroline
Does your shed have any ventilation at all? I wouldn't think adding the polystyrene boards would make much difference if there is no ventilation.. With the warmth of the rabbits and the bedding and the hay / straw there is alot of heat going on, I would drill a view holes near the top walls to allow the shed plenty of breathing space
Back to top
 Alert Moderators
Caroline82
from United Kingdom
PostPosted: Thu Jan 07, 2010 5:13 pm Reply with quote
hello thanks for your reply, it would say there is ventilation the windows aren't air tight as they are made so i can remove them also i go in there a fair bit and i have a stable style door which I have been leaving open to try to help but it has made no difference at all. I wouldn't of thought the rabbits wouldn't produce much heat to be honest if doesn't feel warmer then outside and the bottles are still freezing in there?
Back to top
 Alert Moderators
david191052
from United Kingdom
Thanked: 1 time
PostPosted: Sat Jan 09, 2010 5:34 am Reply with quote
Caroline
If you place insulation under the steel sheet, you are likley to cause more condensation due to air gaps in the profile.
Ideally you will need a VCL ( vapour control layer ) under the insulation.
This is usually achieved on factory building by using two layers of steel sheet with insulation between
First of all is the condensation excessive that it really is a problem ?
Do you have any heating in there ~ if so, I trust it is not paraffin or calor gas ~ these cause more condensation than they are worth
If you need to insulate the roof you may be better doing this over the top i.e place insulation on existing roof and place new steel sheet over
David
www.dha-ltd.co.uk
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
flat roof extension - about to insulate after alterations. 3 280 Wed Oct 27, 2010 9:12 pm
How do I insulate my flat roof 7 500 Thu Dec 16, 2010 12:22 pm
Warm roof - How to insulate an stud upstand for rooflights? 8 160 Thu Aug 11, 2011 9:12 am
How do I insulate a flat roof built in the 70s? 4 1100 Thu Feb 25, 2010 10:11 pm
How can I insulate above the ceiling of my converted loft? 2 100 Fri Sep 23, 2011 11:10 am
DIYnot
