DIYnot
Local | Network
   DIYnot > Forums
Local | Network
How do I increase the pressure bar on my greenstar 30CDI
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
MrWhiskers81
from United Kingdom
PostPosted: Fri Jan 08, 2010 6:24 pm Reply with quote
It is almost at O (about 1mm off) and I know it should be at 1.5 I did bleed a rad this morning...I don't know how to refil - should boiler be switched off?
Back to top
 Alert Moderators
tj351011
from United Kingdom
Thanked: 1 time
PostPosted: Sun Jan 10, 2010 3:41 am Reply with quote
hi
best to repressurise when system cold
slide white plastic cover plate off (underneath bottom of boiler)
there should be a plastic T key clipped to it
take key off, look under the boiler and to the right side theres a black plastic assembley with a white square screw, a hole ( where you put the barrel of the T key) and a black cap.
look carefully at the key there should be an arrow head marked on the handle look at the hole where the key fits there are two symbols of pad locks on it, one is unlocked the other locked. line the arrow on the key up with the unlock symbol push the key in as far as possible and turn so the arrow head lines up with the locked symbol turn WHITE screw anti clockwise to fill boiler to 1.5 bar close white screw fully, take key out replace key and cover. simples icon_wink.gif
ps page 33 of installation and service booklet (should have been left with boiler)
Back to top
 Alert Moderators
Steady
from United Kingdom
Thanked: 27 times
PostPosted: Sun Jan 10, 2010 9:54 am Reply with quote
1.5 bar is too high. 1 bar is the recommended system pressure when cold.
Back to top
 Alert Moderators
raymondpat
from United Kingdom
PostPosted: Thu Oct 13, 2011 7:25 pm Reply with quote
tj351011 wrote:
hi
Thanks for above. 1 small question. When I follow above instructions and turn white screw water begins to trickle out where white key is inserted. Is this meant to happen ? Was wary of continuing just in case it shouldn't. Thanks
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 5050 times
PostPosted: Thu Oct 13, 2011 7:26 pm Reply with quote
You haven't inserted it correctly.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Greenstar 30CDi System - Low Pressure 10 560 Thu Nov 04, 2010 9:33 pm
greenstar 30cdi system boiler. low pressure. 11 880 Fri Sep 17, 2010 2:35 pm
Worcester Greenstar 30CDI-pressure issue 19 11420 Mon Dec 14, 2009 7:23 pm
Greenstar 30CDi low pressure 10 820 Fri May 01, 2009 5:34 pm
Pressure at Zero, Worcester Greenstar 30cdi 11 100 Wed Jan 30, 2013 9:31 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
