mayniak08
Joined: 09 Feb 2005 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Wed Feb 09, 2005 11:06 am Post Subject: MCB Fault Location |
The MCB on my upstairs lighting trips and wont reset.
I have removed all light bulbs ( not sure why ? ) , and also checked the wiring at every switch and every ceiling rose ,but the MCB still trips.
I then one-by-one disconnected a wire from every switch - hoping that this would isolate the wiring in that particular room , and therefore at least highlight which room was causing the problem. This still didn\\\'t help. Should I have disconnected every switch all together , and then one-by-one reconnected and tested the MCB ?
Also I read in one of your posts that the main circuit breaker switch should be turned off before restting the MCB. I haven\\\'t been doing that and have been getting a \\\'flash\\\' when resetting the MCB. Am I doing something very dangerous ?
Finally , is there a standard search procedure to locate the faulty wiring causing the MCB to trip ?
Any help would be appreciated - the candles are nice but .. |
ban-all-sheds
Joined: 27 Aug 2003 Posts: 21990 Location: London, United Kingdom Thanked: 78 times
Posted: Wed Feb 09, 2005 11:53 am Post Subject: Re: MCB Fault Location |
| mayniak08 wrote: | The MCB on my upstairs lighting trips and wont reset.
I have removed all light bulbs ( not sure why ? ) , and also checked the wiring at every switch and every ceiling rose ,but the MCB still trips. |
Have you recently done any work involving drilling, screwing or nailing into floors, walls or ceilings?
| Quote: | | I then one-by-one disconnected a wire from every switch - hoping that this would isolate the wiring in that particular room , and therefore at least highlight which room was causing the problem. This still didn\\\'t help. |
It won't, and if you look at diagrams of lighting circuits you'll see why.
| Quote: | | Should I have disconnected every switch all together , and then one-by-one reconnected and tested the MCB ? |
That would also do no good - you need to start breaking the lighting circuit into segments at the ceiling roses/JBs/fittings, not at the switches. If you look at diagrams of lighting circuits you'll see why.
| Quote: | | Also I read in one of your posts that the main circuit breaker switch should be turned off before restting the MCB. I haven\\\'t been doing that and have been getting a \\\'flash\\\' when resetting the MCB. Am I doing something very dangerous ? |
Well - not safe, and not doing the MCB any good.
| Quote: | | Finally , is there a standard search procedure to locate the faulty wiring causing the MCB to trip ? |
I fear that your lack of understanding of how lighting circuits are wired means that you can't do this yourself.
I'm not being unhelpful - if you can't work out what to do from the circuit diagrams you have no chance of doing it safely or successfully. And do you have any test equipment?
| Quote: | | Any help would be appreciated - the candles are nice but .. |
Time to call an electrician. If from my first Q you can identify where a cable might have been damaged it could shorten his search. __________________ I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth. |
mayniak08
Posted: Wed Feb 09, 2005 3:03 pm Post Subject: |
Thanks for the prompt reply .
That is actually very helpful ; knowing what you don't no is always worth knowing ! .
I guess my school-boy concept of light bulbs in parallel with switches on each one was a little too naive.
Your right , time for someone time served. |
