DIYnot
Local | Network
   DIYnot > Forums
Local | Network
What does a Diverter Valve do ?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
tvrjohn
from United Kingdom
PostPosted: Mon Jan 11, 2010 12:58 pm Reply with quote
Hi
and what are the faults with them ?
Having issue with 28cdi Worcester Combi
Back to top
 Alert Moderators
Al-Glasgow
from United Kingdom
Thanked: 15 times
PostPosted: Mon Jan 11, 2010 1:00 pm Reply with quote
Its a valve that is triggered to activate HW or Heat.
I guess you have HW and no heating or other way round.
There is a good chance it will fail at one point
Back to top
 Alert Moderators
MANDATE
from United Kingdom
Thanked: 130 times
PostPosted: Mon Jan 11, 2010 2:43 pm Reply with quote
The Halstead ace boiler I think is typical.
There is a 'diverter valve' which is movable to the left. When moved it diverts the water from CH circuit to the HW circuit (heat exchanger)
At the end of its travel the valve triggers a microswitch.
You can see a faulty micro switch or a sticky valve and you have problems.
But the main problem is related to the 'diaphram operated switch Assy'.
It's this Assembly that moves the valve. How?
The Diaphram has mains water on both sides of it. When the hot tap is opened the pressure on one side is reduced. This allows the pressure on the opposite side to push the valve across. If this diaphram is split/holed the higher pressure water passes to lower pressure side. The result being the valve does not move or may move slightly, but not sufficient to light boiler.
This I believe accounts for many problems when no HW on a combi
Back to top
 Alert Moderators
tvrjohn
from United Kingdom
PostPosted: Mon Jan 11, 2010 10:56 pm Reply with quote
Back to top
 Alert Moderators
olly_k
from United Kingdom
Thanked: 6 times
PostPosted: Tue Jan 12, 2010 1:55 pm Reply with quote
I repaired a diaphragm on a Vailant boiler quite an easy job apart from the rusted screws! Had to do both diaphragms.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3616 times
PostPosted: Tue Jan 12, 2010 1:59 pm Reply with quote
The Halstead Ace is the best kind of diverter valve.
The most common type as used on Worcesters have a manifold section which has to follow the DHW bit under spring pressure and often gets stuck but you cannot see what its doing.
Tony
Back to top
 Alert Moderators
jon0881
from United Kingdom
PostPosted: Tue Jan 12, 2010 7:18 pm Reply with quote
Mine has gone one further and leaked water out of it and into the plug which is popping the 3A fuse.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Potterton Performa 28 - Leaking Diverter Valve Front Section 14 4380 Wed Jul 22, 2009 9:44 am
vaillant turbomax plus diverter valve 7 520 Sun Jul 19, 2009 3:43 pm
Replacing Diverter for Mid Position Valve wiring question. 17 1160 Sun Jul 19, 2009 12:12 pm
2 x 2-port versus 1 x 3-port diverter valve 23 1140 Tue Jul 14, 2009 12:30 pm
vaillant 242E - diverter valve changed but STILL hot rads 10 780 Sat Aug 08, 2009 5:08 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
