DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Key wont come out UPVC lock when locked
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
kevtrydiy
from United Kingdom
PostPosted: Wed Jan 13, 2010 9:10 am Reply with quote
My door will lock and unlock open and close easily, but when I lock the door the key wont go passed 1 oclock to line up vertically and come out.
I can get the key vertically and out when it its unlocked just not when locked even if the door is open or closed.
I took the barrel out and it spins freely which I thought it might as the key spins ok to lock and unlock.
Why is it stopping there?
Back to top
 Alert Moderators
HandyHands
from United Kingdom
Thanked: 16 times
PostPosted: Wed Jan 13, 2010 10:50 am Reply with quote
The cam (black bit in the middle of the cylinder that rotates) has slipped out of position. With the key withdrawn, and the cylinder held vertically, it should be at 5 or 7 o'clock (narrow section towards the bottom). I'm guessing it's more like 11 or 1 o'clock.
Usually occurs when a key is already in the reverse side of the cylinder, and a key then inserted from the other side and rotated to open the cylinder.
It can be fixed, but if its happened once - its very likely to happen again. Best bet is to buy a new cylinder - just make sure it's the same size as the one currently fitted.
Back to top
The following user says thank you to HandyHands for this useful post:
kevtrydiy (13 Jan 2010)
 Alert Moderators
kevtrydiy
from United Kingdom
PostPosted: Wed Jan 13, 2010 8:55 pm Reply with quote
Exactly that! Cheers. Since it has slipped can I get it to slip back?
Its just a patio door so not important but want key out lock for eyes!
If I have to buy one can you explain the 5 pin for 5 or anit bump for 30 on screwfix?
Cheers for your knowledge.
Back to top
 Alert Moderators
HandyHands
from United Kingdom
Thanked: 16 times
PostPosted: Wed Jan 13, 2010 10:03 pm Reply with quote
The correct way would be to strip the cylinder down, reset the cam, then put it back together again. Alternatively, you can insert keys into both sides of the cylinder and try to "force" the cam around. Personally, I'd just stick a new cylinder in.
With regards to UPVC door security - my opinion is that spending a large amount on cylinders is a waste, as you're unlikely to have the cylinder picked, bumped, or snapped (as long as the correct size is fitted). If someone wants into your house, it's far easier to cave the door in, or force the mechanism open.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Multipoint lock in UPVC door wont work 5 6820 Sat Mar 26, 2011 5:57 pm
UPVC front door wont dead lock from the inside 7 4520 Thu Apr 05, 2007 2:39 pm
uPVC door lock wont close very well 5 940 Wed Jul 29, 2009 9:07 am
UPVC FRENCH DOORS WONT LOCK 11 880 Mon Dec 06, 2010 11:15 am
window wont lock 4 520 Fri May 23, 2008 1:34 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
