hi there can anyone help me. i am in the process of removing my washers drum to replace the bearings and im stuck cant move the 2 plastic pins that hold the drum to the lower suspension brackets does anyone know how to? any help would be most gratefull.
I recall the same problem about 18 months ago.
I think it was a plastic peg about 15mm in diam. with a machined slot down the axis. I had to use pliers/grips to squeeze and reduce diam. then tap pins out.
If I remember correctly I removed the brackets and the drum assembly first.
I wish you luck
