Joined: 10 Feb 2005 Posts: 639 Location: Moray, United Kingdom Thanked: 0 times
Posted: Fri Feb 11, 2005 6:33 pm Post Subject:
The neutral should not go to the switch. There are 2 ways to wire up a 1 way light. One is to take a mains supply to the light fitting and run a T & E cable from there to the switch. Ceiling roses have a terminal marked loop for connecting the mains live to the switch cable. The black wire from the switch cable should have a bit of red insulation wrapped round it each end to show it is the switched live. This goes to one side of the bulb, the neutral to the other.
The second method is to run a mains cable to the switch and connect its live wire to the switch. Another T & E cable carries the live and neutral to the light fitting. In this case you need a 5 amp terminal, sometimes known as a chocolate block terminal to connect the mains neutral and light cable neutral wires together.
Joined: 11 Feb 2005 Posts: 4 Location: United Kingdom Thanked: 0 times
Posted: Fri Feb 11, 2005 10:37 pm Post Subject:
hi
i have a wire three wires live,nutrel and earth
live go in the switch were its marked com the nutrel gos to a seperate nutrel else were?
the the wire going to the bulb the live into 1 and nutral into two
sorry about th spelling, i can,t use spell check when i press on the link nothing comes up
Posted: Fri Feb 11, 2005 10:56 pm Post Subject:
hi
its a new switch into the loft i runing a wire from a from a junction box
and i don,t under stand the paperwork with the new switch but when i wired it up it blows the fuse, i put the two nutrels to gether and i think thats what it was, so going of the postings the nutrel from the junction box gos to a dirrent nutrel ,not in the switch, it might be ease for you
but not me but if i new some think you did,t i would not get shirty with you
thanks
hugh
Joined: 14 Sep 2004 Posts: 3972 Location: United Kingdom Thanked: 0 times
Posted: Fri Feb 11, 2005 11:07 pm Post Subject:
hughoel wrote:
hi
thanks
hugh
see the for reference section. youll find that there is NO neutral at the switch. the black is a switched live. changing a lightswitch is easy. just take off the old one and connect the new 1 using the same terminals. if you dont understand this then get someone else to do it
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Fri Feb 11, 2005 11:08 pm Post Subject:
it often helps when asking a question to give as much information as possible. in your case you are adding a light to your loft.
in that case i suggest you look in the "for refernce section" you will find there a drawing that shows you exactly how to do what you are trying to do.
__________________ Do you like music Mr Finch?
Forum = Opinions
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
