DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Plasterboard Support for Ceiling
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering
Author Message
sv969
from United Kingdom
PostPosted: Mon Jan 18, 2010 10:55 am Reply with quote
I have just hade a new extension built and prepared some internal wooden studwod to form 3 internal rooms.
I plan to plasterboard both the ceilings and the walls with 12.5mm board with a final skim coat.
If I fit the ceiling boards first, is there any need to cut and fit wooden noggins around the permiter of the ceiling area to support the board edges or is it OK to rely on the plasterboards fitted to the walls to provide the support if they are pushed up tight against the ceilign boards?
Hope that makes sence.
Simon
Back to top
 Alert Moderators
mac391
from United Kingdom
Thanked: 67 times
PostPosted: Mon Jan 18, 2010 6:31 pm Reply with quote
The ceiling joists should be spaced at 300/400mm centres. no need to add noggins as 12.5mm plasterboard has enough strength but should be nailed every 8 inches right up the edge of the ceiling.
sv969 wrote:
Simon
Back to top
 Alert Moderators
PrenticeBoyofDerry
from United Kingdom
Thanked: 1787 times
PostPosted: Mon Jan 18, 2010 7:40 pm Reply with quote
The timbers should be spaced out no more than 400mm about 16 inch.
It's always good to have nogins, this will reduce the sag of the board. But the the ceiling board will rest okay of the wall board providing it is fitted tight up.
Back to top
 Alert Moderators
DIYnewbee99
from United Kingdom
Thanked: 114 times
PostPosted: Mon Jan 18, 2010 9:04 pm Reply with quote
mac391 wrote:
.... 12.5mm plasterboard has enough strength but should be nailed every 8 inches right up the edge of the ceiling.
Would drywall screws be more secure than nailing?
Back to top
 Alert Moderators
Greg20
from United Kingdom
PostPosted: Mon Jan 18, 2010 10:18 pm Reply with quote
Drywall screws are much more secure then nails.
Nail every 8 inches, screw every 18 Thats how i work it.
Back to top
 Alert Moderators
roughcaster
from United Kingdom
Thanked: 538 times
PostPosted: Tue Jan 19, 2010 12:13 am Reply with quote
Although the ceiling p/board edges will sit onto the top of the wall board, i'd put noggins around the perimiter of the ceiling, and fix the boards with screws,,, much stronger all round.
Roughcaster.
Back to top
 Alert Moderators
roy c
from United Kingdom
Thanked: 322 times
PostPosted: Tue Jan 19, 2010 12:54 am Reply with quote
I would screw it all at 6-8 inches I think 18 is too big a gap inbetween screws... icon_wink.gif
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Tue Jan 19, 2010 1:52 pm Reply with quote
You can fit noggins but if you’ve a 400 or 450mm joist pitch, personally, I wouldn’t bother; obviously fit a support joist against the opposing walls to provide support on those two edges. Fit the wall boards up tight & tape; make sure you lay the ceiling board’s long edge across the joists, butt close & stagger the joints.
Never use nails; screws are a lot easier, far more secure &, unlike nails, don’t relax their support over time leading to popped nail heads & cracking. 18 inch spacing is far too much, personally I fix around every 6 inches.
Back to top
 Alert Moderators
Greg20
from United Kingdom
PostPosted: Tue Jan 19, 2010 2:28 pm Reply with quote
Thanks for the advice Richard ( And Roy c also).
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering All times are GMT
Page 1 of 1
Jump to:
Does Plaster Support anything? 2 300 Thu May 06, 2010 9:45 am
Plasterboard Ceiling and LIGHTS 2 160 Sat Jul 09, 2011 12:17 pm
Plasterboard ceiling and joint filling help 14 3980 Mon Feb 01, 2010 5:34 pm
Overboarding existing bathroom plasterboard ceiling. 6 1120 Thu Apr 22, 2010 9:12 pm
Joists for suspended plasterboard ceiling 5 800 Tue Nov 25, 2008 3:19 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
