First of all hi to all here as this is my first post for help as a new user of this grate site.
My problem as stated above is the overflow pipe on my cold water tank that is located in the loft. The problem started around 2 months ago. Some times the dripping can be very fast, more of a flow that a dripping really.
I have adjusted the ball end, and that sim to work ok as it does stop the flow of the water. The only thing that I’m not quite sure if it's right or not is the overflow pipe inside the tank. It’s the elbow type. The water flow stops way bellow the horizontal point of the pipe. The vertical point it’s not quite vertical, it’s in an angle and half of it it's in the water. My question is, does the overflow pipe need to be in the water.
Many Thanks for any advice
Nikos
Nikos
