Terminal Block and 'Wrapping with Tape'
11 May 2004
Hampshire
I'd like, if I may, to cast myself upon the mercy of the forum yet again..... :confused:
I have the instructions for a ceiling mounted luminaire. This states that the loop-in terminal block (a very standard bit of 4 way choc block supplied with brown, blue, earth already connected) should be 'wrapped in electrical tape once wiring is complete'.
Now since the backplate is flush mounted to the ceiling, and the pre-fitted choc block is on the outside (and not particularly an integral part of the light fitting), the only place to put it is in the ceiling void.
This seems to run contrary to some of the threads here recently - in fact I have a dim recollection of a similar question.
Can anyone advise if this one of those Bad Things, or not?
Ta!
its accessable. i.e it can be found if needed, and is in a obvious place. they shouldnt be used buried in walls etc. i sometimes tape the connectors but most of the time i dont
best use
from tlc
breezer said:
best use
from tlc
do we have to use that background aswll? mayb be too big to fit thru a small hole above a light :D
Thx guys - the choc block cover looks smart.
Off topic follow-up question ..... what is that wiring shown in the picture? Telephone or Alarm system?
its telephone cable (you can tell by the white stripes in the colours, green with white stripes)
either phone cable or twisted pair network cable
from the core count i suspect the latter.
note: if you want to run at 100mbit this is probablly not the smartest way to join network cable.
