DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
spur from a lighting ring
This topic originated from the How to page called Adding a spur to a ring circuit from a junction box
Click here to return to the page called Adding a spur to a ring circuit from a junction box.
  View previous topic :: View next topic
Author Message
symonbrum
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 13, 2005 8:46 am    Post Subject:
Reply with quote Thanks
I need to create a socket from a through wall into a garage which has only one existing electrical socket which is already spurred. There is however an accessible cable close by leading to the light switch for the garage. Can I spur from here using a 30a JB? I have it in my head that I can't but don't know why. If not what options do I have?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Feb 13, 2005 10:50 am    Post Subject:
Re: spur from a lighting ring
It looks like you are saying you want to put a soket on a cable that you know goes to a light switch?
I am happy to say thankyou for asking, but the answer is that you should get 3 quotes from electricians to do the job, as the to do the job will be breaking part p (try a search) and judguing by your question you have no idea about electrical wiring and its principals
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
felix
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 13, 2005 12:31 pm    Post Subject:
Leaving part P aside for the moment, there are reasons other than fickle political whim why you can't do it.
For a start, you are highly unlikely to find a neutral wire leading to a light switch. What you will most likely find is a flat twin and earth cable in which the black wire is switched live, not neutral. If you connect a socket across these two, nothing much will happen - until you try to use the socket. The light will come on and whatever you plugged in won't work properly.
Even if you follow that wire back to a its light fitting or junction box where there will be a real neutral, putting a socket on a lighting circuit is a bad idea because they are only rated at five amps - or six if you're lucky. Every time somebody tries to use that socket for something big, like a washing machine for example, the fuse in the consumer unit will blow and lots of lights will go out.
Your new socket should, like the other one, be spurred off a 30 amp circuit. If you can't figure out how to do this then take Breezer's advice and find somebody who can.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
lighting spur from a ring main/socket 25 5820 Sun Dec 02, 2007 10:22 am
fluorescent lighting spur from ring main socket. 6 640 Sun Mar 04, 2007 6:21 pm
Extending Socket Ring Main and adding a lighting spur 12 1640 Tue Oct 02, 2007 5:35 pm
Spur off ring 9 280 Wed Sep 17, 2008 12:23 am
Spur off ring main FCU 5 200 Sat Jan 17, 2009 9:11 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
