DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Central Heating Pump Runs Continuously
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
JB1
from United Kingdom
PostPosted: Sat Jan 23, 2010 3:44 pm Reply with quote
Hi, Any ideas please. My central heating has been running fine up to about a week and half ago when the cold the cold weather hit. Now the CH pump will not shut down it runs 24x7 whether the heating is on or off. I've tried changing the frost stat ( The boiler is in the garage) the pump overrun stat on the boiler and the overheat stat on the boiler and the thing keeps on running. Any ideas?
The pump is a grundfoss and the boiler is a Potterton Netaheat Profile 80e.
The CH and HW are working fine and the boiler works fine when the timer kicks in.
Help!!!
Back to top
 Alert Moderators
tomy
from United Kingdom
Thanked: 14 times
PostPosted: Sat Jan 23, 2010 4:53 pm Reply with quote
Two port or three port valve is faulty
Back to top
 Alert Moderators
JB1
from United Kingdom
PostPosted: Sat Jan 23, 2010 6:14 pm Reply with quote
Yep I thought that might be the case. But when I turn off the CH and the HW independantly. They both activate.
Back to top
 Alert Moderators
Corgigrouch
from United Kingdom
Thanked: 410 times
PostPosted: Sat Jan 23, 2010 6:26 pm Reply with quote
Which boiler is it?
Back to top
 Alert Moderators
JB1
from United Kingdom
PostPosted: Sat Jan 23, 2010 6:52 pm Reply with quote
Back to top
 Alert Moderators
gas112
from Unknown or unspecified country
Thanked: 2294 times
PostPosted: Sat Jan 23, 2010 8:38 pm Reply with quote
Does the boiler boiler fire up as well every so often if so its microswitch in motorised valve.
If it doesnt it will be the pump over run stat in boiler at fault
Back to top
 Alert Moderators
steve32
from United Kingdom
Thanked: 92 times
PostPosted: Sat Jan 23, 2010 8:40 pm Reply with quote
micro switch in the mv is stuck on
you may be able to free it or replace head
Back to top
 Alert Moderators
JB1
from United Kingdom
PostPosted: Sun Jan 24, 2010 11:21 am Reply with quote
Ok so which one or both MV's do I change. The system has 2 x 2port MV's fitted. I've had a play this morning and they seem to be working ok but the HW MV was sticky. Pump is still running with the system off. Also the boiler does cut in intermittantly when the HW and CH is turned off on the timer.
Back to top
 Alert Moderators
tomy
from United Kingdom
Thanked: 14 times
PostPosted: Sun Jan 24, 2010 11:50 am Reply with quote
check the wiring to see which one or maybe both will feed the boiler then disconect and test with a multimeter to see which valve is supplying 240v to the boiler when it shouldnt be.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Gledhill Boilermate 2 Pump Runs Continuously 11 440 Mon May 27, 2013 2:37 pm
Pump runs continuously (no CH/HW call; boiler switched off) 16 10980 Thu Feb 19, 2009 3:59 pm
Circulationg pump runs continuously 16 1680 Mon Sep 26, 2005 8:10 pm
Pump Runs Continuously 2 2620 Tue Dec 26, 2006 11:31 am
Pump runs continuously 24 260 Sun Jan 08, 2012 7:03 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
