DIYnot
Local | Network
   DIYnot > Forums
Local | Network
potterton netaheat profile not staying on
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
GUYVER1
from United Kingdom
PostPosted: Tue Jan 26, 2010 11:00 pm Reply with quote
Hiya All..
having a real nightmare with a 'POTTERTON NETAHEAT PROFILE 50e' The old school system boiler
On an 8 rad system it fires up and will only stay on longest on temp marks 2-3. One rad will not fill up at all. (could the boiler be locking up due to this rad acting as a massive airlock??)The boiler will not stay on long for any other temp mark and needs resetting every other day. Heat only generates on the upstairs rads and the first rad from the boiler is always hot no matter what.
Before i start spending could anybody give me any ideas to what the cause may be or is a combi install imminent???
Thanks and suggestions
Back to top
 Alert Moderators
twgas
from United Kingdom
Thanked: 422 times
PostPosted: Tue Jan 26, 2010 11:11 pm Reply with quote
Check to see if the pump's working.
Back to top
 Alert Moderators
screech
from United Kingdom
Thanked: 49 times
PostPosted: Tue Jan 26, 2010 11:19 pm Reply with quote
why would you want a combi boiler?
is the system running dry? i.e empty header tank or a blocked cold feed. if you can't bleed the rads then i'd check that first.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3534 times
PostPosted: Wed Jan 27, 2010 12:42 pm Reply with quote
The Netaheat Profile is quite repairable as long as there are no holes in the casing.
The earlier Netaheats are reliable but many parts are no longer available.
As stated, a pump or feed problem seems likely. Not really the boiler's fault although a good service would be a good idea.
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Potterton suprima boiler staying on! 6 320 Mon Dec 21, 2009 10:16 am
Problem With Pan Connector Not Staying On 5 540 Mon Sep 01, 2008 6:57 pm
Gas central heating staying on all the time! 2 520 Mon Oct 06, 2008 8:09 am
Hot Water Staying On 4 320 Thu Nov 20, 2008 3:23 pm
staying alive...maintaining ancient radiators 12 1020 Mon Dec 03, 2007 2:04 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
