Is this work notifiable
2 Mar 2007
Southampton
I am removing an immersion tank in my home, heated by economy 7 and normal unrestricted supply, which involves removing the night storage timers etc and ancilliary wiring. I shall probably employ a qualified electrician to do the job but is this notifiable work? The articles on 'Part B' regs only refer to Installing new work but nothing about removing existing installation. Your advice will be much appreciated before I get the work done.
Since it's decommissioning, it's of no interest to anyone.
Safety and safely apply. Take wires out the CU and remove the complete route as much as you can.
The CU label for the fuse / mcb should be adjusted to be marked as spare.
How are you going to get hot water then?
May be a good idea to leave the immersion in as a backup perhaps?
