HW is scalding hot (always has been), just wondering how to confirm 100% if Mid Pos Valve is faulty? I have tried turning cyl stat down to 50 and makes no difference, when I turn it up and down past the click I can here the valve opening and flow pipe to cyl gets hotter.
I have removed head and checked spindle can just about move with fingers, and can move easily with pliers - also moved head lever to manual when CH is off and can feel resistance so seems OK.
I've checked the flow pipe into to cylinder after CH has been off and cyl stat turned right down and it gets v hot, slightly cooler than CH side but not much. Is this normal due to heat transfer?
Do you think valve is suspect/passing?
