problem with keston qutos 28s boiler
5 Feb 2010
Norfolk
BOILER RUNS OK FOR A TIME THEN BUILDS UP PRESSURE AND DISCHARGES VIA SAFETY VALVE THE PRESSURE THEN DROPS TO LOW TO RUN BOILER ANY HAD THIS ???
air or debris in the system?
but i would go with a dodgy pressure sensor, call someone out and make sure he brings one of them ;)
Not worked on one of these so checked my computer... the boiler doesn't seem to have an expansion vessel so ain't pressurised...have I got the right boiler? That being the case you obviously have the system pressurised anyway. You need to go to the pressure vessel, hold open the PRV and attach a foot pump to the schrader valve on the vessel and pump the pressure to whatever the data badge says...standard is about 1 bar, bigger ones are 3,5bar.
Hope I ain't completely missed the mark here
There is the Q28h (open vented) and Q28s (sealed)
Q28h doesn't come with an internal pump or expansion vessel the Q28s does.
I would still go with the pressure sensor (trust moi) but wont rule out blooflames comment. should be 1bar at the vessel.
