DIYnot
Local | Network
   DIYnot > Forums
Local | Network
White paint turns yellow
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
brittas2009
from United Kingdom
Thanked: 2 times
PostPosted: Mon Feb 08, 2010 11:06 pm Reply with quote
We decorated a room about 5 months ago and have noticed that the white eggshell on the skirting boards etc has already started to yellow. I have seen it loads of times in the past with white gloss so hoped eggshell might be better. icon_cry.gif
It's not a cheap make and it was a brand new tin when we did it. Any ideas how we can make it stay whiter for longer or is there a particular make of white eggshell that is better than Dulux?
Many thanks
Back to top
 Alert Moderators
LJW61
from United Kingdom
Thanked: 63 times
PostPosted: Tue Feb 09, 2010 12:10 am Reply with quote
All oil/solvent-based (white) paint will yellow after a while , even more so if theres no natural (sun)light in the room..
Back to top
 Alert Moderators
wallcoatingsbloke
from United Kingdom
Thanked: 2 times
PostPosted: Fri Feb 12, 2010 1:35 pm Reply with quote
......i think the above was someone spamming the site.
How about this, hope this helps you.
Its tricky to say for sure without seeing the job but here are my two pennies worth...........
1. Did you thoroughly MIX the paint? before using it? I know sounds daft saying it, but sometimes people dont mix it, and therefore the resins in the gloss have appeared as they weren't amalgamated into the paint.
2. Is there a HEAT SOURCE (hot water or heating pipe, vent from flue or aircon unit, radiator etc) near the stained wood as heat can discolour paint.
3. Did you PREPARE the surface before painting, by sanding the old paint, getting shot of the dust from that, and making sure the wood was CLEAN before painting?
and finally
4. Did you use a BRAND NEW brush to apply it or was the brush stored in turps, or used for a darker colour previously?
Hope the above is helpful to you.
Good luck.
Back to top
 Alert Moderators
pom001
from United Kingdom
PostPosted: Sat Feb 27, 2010 11:07 pm Reply with quote
I had the same issues with white oil based paint
It will go yellow very quickly if it does not have natural daylight, the less light the quicker it wil happen.
Either use a water based gloss, they dont go yellow, but give a crap finish as they dry too quickly or choose another colur other than white
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
White emulsion paint turning yellow 6 240 Wed May 11, 2011 9:18 pm
Brilliant white gloss paint making all woodwork look yellow 7 3020 Mon Nov 17, 2008 10:32 am
White paint going yellow!!! 4 180 Tue May 08, 2012 10:27 am
Dulux sued because its BRILLIANT WHITE paint fades to yellow 58 25800 Fri Apr 06, 2012 2:10 pm
Im looking for WHITE GLOSS PAINT that will not turn yellow 2 380 Fri Nov 28, 2014 11:11 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
