DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Leaking connection between toilet pan and waste pipe...
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Lusi83
from United Kingdom
Thanked: 7 times
PostPosted: Wed Feb 10, 2010 9:10 pm Reply with quote
I have a slow leak behind the toilet pan between a concertina fixing and a solid plastic waste pipe.
Don't think they are lined up particularly well - the joint is smothered (1 inch thick) in some white sticky stuff (I think it might be plumber's mait????)
Bathroom was installed (before I bought the house!) by a DIY bodger (don't start me on the no of problems I've had.... to give an idea he moved the cistern to make it concealed - but neglected to move the overflow or change it for an internal overflow -icon_rolleyes.gif I didn't know I had a problem until the ceiling downstairs caved in... )
Now at breaking point - I have concluded that the whole bathroom needs to be ripped out and redone ...
But I need a bodge to stop it leaking while I get quotes/plans/etc/etc ...
So is the white gunk plumber's mait? Will it work?
Can I just put more on top or do I need to get rid of some of the old stuff first? Is there an easy way of getting rid of the white gunk?
Back to top
 Alert Moderators
omegaman
from United Kingdom
Thanked: 9 times
PostPosted: Wed Feb 10, 2010 9:27 pm Reply with quote
Sounds like plumbers mait, another cowboys favourite is silicone (but that doesnt work either).
Sounds like the rubber has dislodged from the pan connector. You could try and push the rubber in bit more or take it out and redo it properly. You'll need to clean all that gunk off though.
Maybe someone else can suggest a better solution.
Back to top
The following user says thank you to omegaman for this useful post:
Lusi83 (11 Feb 2010)
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2600 times
PostPosted: Wed Feb 10, 2010 9:41 pm Reply with quote
The only real way to sort this is to remove the loo from the waste pipe and renew the pan connector.....use Toolstation's 72849 if the connection is straight, but if its out of line a bit then 55280 is the one to go for.
No amount of bodging on these seems to work!
Back to top
The following user says thank you to Burnerman for this useful post:
 Alert Moderators
Lusi83
from United Kingdom
Thanked: 7 times
PostPosted: Wed Feb 10, 2010 11:06 pm Reply with quote
Thanks -
Trying not to make this into too big a job...bit scared of taking it off altogether...sounds like it could become a nightmare (and this is our only loo!)icon_eek.gif
And really am going to get the whole thing redone....it is one problem after another...
Does anyone know how I can get the gunk off - maybe if I could see what was going on underneath I would have a better idea of whether I need a new connector -or if it is just pushing it together a bit better....
I can manually take some of it off but will anything dissolve it?
And if I can push it together properly (or get a new connector) what -if anything should I seal it with?
Thanks again
BTW When I first looked at the picture of the toolstation offset connector - I thought that won't work - we need one that bends the opposite way...and then I thought about it a bit more ...durrrrr icon_redface.gif - really don't think I can be trusted replacing the whole pipe!
Back to top
 Alert Moderators
tamz
from United Kingdom
Thanked: 276 times
PostPosted: Wed Feb 10, 2010 11:11 pm Reply with quote
As said
If you are really stuck this Will work http://www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=9265158&ecamp=trf-005&CAWELAID=266879365
Back to top
The following user says thank you to tamz for this useful post:
 Alert Moderators
Lusi83
from United Kingdom
Thanked: 7 times
PostPosted: Wed Feb 10, 2010 11:53 pm Reply with quote
Is this a wind up? Or will it really work...looks too good to be true....
I'm all up for bit of cowboying for a short term solution.... icon_biggrin.gif
Back to top
 Alert Moderators
dextrous
from United Kingdom
Thanked: 194 times
PostPosted: Thu Feb 11, 2010 12:02 am Reply with quote
It really will work - sticks like the proverbial (which is ironic, in light of where you're going to use it). Just make sure that everything is as dry as dry can be, and wear gloves ('cos it will stick to your hands).
Back to top
The following user says thank you to dextrous for this useful post:
 Alert Moderators
tamz
from United Kingdom
Thanked: 276 times
Cust: Can i paint that?
You: You can try icon_lol.gif
Back to top
 Alert Moderators
neds
from United Kingdom
Thanked: 27 times
None of these quick fixes will likely last. If you want to save the tears later on do it properly remove the pan and get the new fitting in place. Not a big job really and peace of mind its not going to leak.
Back to top
The following user says thank you to neds for this useful post:
 Alert Moderators
tamz
from United Kingdom
Thanked: 276 times
PostPosted: Thu Feb 11, 2010 12:10 am Reply with quote
Denso will last as long as you want to look at it
Back to top
 Alert Moderators
newgas
from United Kingdom
Thanked: 365 times
PostPosted: Thu Feb 11, 2010 12:16 am Reply with quote
The concertina part of the connector will probably need pushing in the fixed plastic pipe , it has prob. come out get it back in by pushing it in bit by bit working your way round it, it will give you a bit of time before you can do it properly icon_wink.gif
Back to top
The following user says thank you to newgas for this useful post:
 Alert Moderators
tamz
from United Kingdom
Thanked: 276 times
PostPosted: Thu Feb 11, 2010 12:22 am Reply with quote
Naw: The pan connector will be sitting at a mad angle to the pipe and will have been filled with silicon or plumbers mate. No amount of pushing, pulling or wiggling will get it right without taking it out and doing it properly.
The denso will work in the meantime.
Back to top
 Alert Moderators
newgas
from United Kingdom
Thanked: 365 times
PostPosted: Thu Feb 11, 2010 12:24 am Reply with quote
Not arguing Tamz icon_wink.gif just giving an alternative
Back to top
 Alert Moderators
tamz
from United Kingdom
Thanked: 276 times
PostPosted: Thu Feb 11, 2010 12:34 am Reply with quote
The OP has i think, limited DIY skills and doesn't want to take it out. Denso is the easiest guaranteed quick fix until he gets round to getting it refitted. Easy. Wrap around a few times and smooth out.
Take longer to clean your hands afterwards (and everything else you manage to touch) icon_lol.gif
Back to top
 Alert Moderators
Lusi83
from United Kingdom
Thanked: 7 times
PostPosted: Thu Feb 11, 2010 12:37 am Reply with quote
Ok
First icon_wink.gif I'm going to buy some Denso tape
Then I'm going to try and get rid of as much of the white gunk as poss...and wriggle the connector about....and see if I can get it a bit closer...
Then if that doesn't work I'm going to stick the denso tape on....
And then if I still haven't got any closer to getting a new bathroom in a month -
First I'll find the number of a local emergency plumber...and then I'll try and replace the connector...
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
New toilet leaking from waste connection 3 1000 Wed Jan 27, 2010 9:49 am
Toilet waste pipe 90 degree connection at outer wall 7 180 Thu Dec 04, 2014 12:42 pm
Toilet Waste Soil Pipe Connection 16 25680 Sun Mar 16, 2008 8:47 pm
Toilet waste connection 6 180 Mon Mar 24, 2014 12:42 pm
Lead waste connection at the back of toilet pan 3 1840 Fri Jan 26, 2007 8:16 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
