DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Bath extractor fan won't turn off
Author Message
punjabi
from United Kingdom
PostPosted: Sun Feb 14, 2010 2:07 pm Reply with quote
Hi All,
I have a Silavent 354511 model extractor fan fitted in a flat (probably about 15 years old, when
flats were orginally built). It's on a pull-cord, and comes on okay, but won't turn off
at all when the light is turned off. So, I opened it up, and set the timing mechanism to
the minimun of 1 min, and lo and behold it turned off after about a minute. But when I put the
cover and casing back on, and screwed it back to the ceiling, it stopped turning itself off
at all. I tried this a few times, and each time, I managed to get it to turn off after a minute
when it's out of the housing, and hanging loose on the cieling, but everytime I put it all
back together, it carrys on running and running.
I find this most peculiar. At one time it did run at all, and I messed about with it, and then
it came on. I can't replace is easily, as the housing where the fan goes is much larger than the
fans which we buy these days from DIY store. The silvent.co.uk web-site no longer lists this model.
Any thoughts? Ideas?
Back to top
 Alert Moderators
nozspark
from United Kingdom
Thanked: 34 times
PostPosted: Sun Feb 14, 2010 2:46 pm Reply with quote
I think 15 years is pretty good going for an extractor fan!!
Post a picture of it and someone might know of a similar sized model..
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 471 times
PostPosted: Sun Feb 14, 2010 4:35 pm Reply with quote
Have you had it off? (THE FAN I MEAN!!)
Look here for a replacement, or ring them up with your dilemma.
www.silavent.co.uk
Back to top
 Alert Moderators
skenk
from United Kingdom
Thanked: 61 times
PostPosted: Sun Feb 14, 2010 6:03 pm Reply with quote
I've seen Silavent Mayfair Classic's last more than 20 years (well not seen them start to finish at my tender age but good reason to believe they are 20yrs+), well worth it at 100 odd a pop.
To the OP, strange that it works while hanging out, sounds like it could be some kind of short between the live and switched live, worth checking for damage to all visible wiring (with power OFF)
Back to top
The following user says thank you to skenk for this useful post:
punjabi (14 Feb 2010)
 Alert Moderators
Page 1 of 1
Jump to:
Shower Extractor Fan doesn't turn off 21 1300 Mon Apr 27, 2009 1:28 pm
EXTRACTOR FAN THAT WON'T TURN OFF! 2 760 Tue Nov 07, 2006 9:06 pm
New light fittings in lounge - won't turn off 23 400 Sun Feb 12, 2012 4:04 pm
Garage light to turn on when doors open 8 180 Fri Nov 18, 2011 10:55 pm
Underfloor heating control unit goes blank, won't turn on 3 220 Mon Sep 24, 2012 2:43 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
