I have a zanussi FJS1225 W which is 7-10 years old. Never had any problems with it but last night I started getting a problem where the drum starts to spin (during the spin phase of the cycle) but only seems to work for a couple of seconds before it sounds like it cuts out and the drum spins for a bit longer and comes to a stop. Then after a minute or two it will try to spin again for a second or two but then stop. This repeats but it cannot spin properly. Just in case it was cutting out from weight imbalance I tried it again empty but the same thing happened.
I have searched on the web and seen some advice around changing the brushes on the motor (it is the original motor and has never been serviced) but I wondered if any one has some advice and options. I am going to pull it out and look it over tonight after work so tips would be good.
Thanks!
F
Thanks!
F
