DIYnot
Local | Network
   DIYnot > Forums
Local | Network
PVA mix as a primer/sealer - How long does it take to dry?
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
taz999
from United Kingdom
PostPosted: Mon Feb 21, 2005 10:15 pm Reply with quote
Hi.
I intend to use diluted PVA as a primer/sealer before I emulsion the walls. How long do I have to wait before I apply the 1st emuslion coat after I have applied the PVA mix. An hour, 2 hours, overnight, 24 hours ? The plaster is well dry.
Will be using 5 parts water to 1 part PVA. By the way wots the difference between a sealer and a primer, if any?
Any advice would be appreciated.
Taz
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Mon Feb 21, 2005 10:27 pm Reply with quote
would it not depend on:
ambient room temp
absobtion rate of plaster
thickness of plaster.
try it tomorrow and see how it goes
Back to top
 Alert Moderators
Panjandrum
from United Kingdom
PostPosted: Mon Feb 21, 2005 10:48 pm Reply with quote
You'll be able to tell by looking at it.
Like breezer says, it depends on the conditions and how much you put on.
But if it's inside and warm and ventilated and you start NOW it should be OK by tomorrow night icon_smile.gif icon_smile.gif
Back to top
 Alert Moderators
confidentincompetent
from United Kingdom
Thanked: 1 time
PostPosted: Mon Feb 21, 2005 11:10 pm Reply with quote
[quote="taz999"]Hi.
Presume walls are bare plaster? If so It is best to prime walls with a thinned coat of emulsion. A thinned coat will soak into plaster and make a perfect bond a further 1/2 coats of emulsion more round (thicker) will give you a nice solid base for the rest of that walls life. icon_wink.gif
good luck
Back to top
 Alert Moderators
jbonding
from United Kingdom
Thanked: 2 times
PostPosted: Mon Feb 21, 2005 11:34 pm Reply with quote
i agree with con all the painters on site water the emulsion down for their first coat on fresh plaster.
Back to top
 Alert Moderators
taz999
from United Kingdom
PostPosted: Tue Feb 22, 2005 12:31 am Reply with quote
Thanks for your reply guys. Guess I should have provided a bit more info:
90% of the house has been skimmed over the exiting old plaster/wall. There's small areas which have been plastered over platerboard and other small areas plastered over bonding coat.
There is heating in the house, but I dont I will have much ventilation this week as I cant find my thermals icon_razz.gif
I have painted the ceilings in a couple of bedrooms. Here I decided to go for Polycell crack free ceiling paint. Didnt have any cracks up there, but hopefully that paint will ensure I dont have any in the future. However noticed one or two hairline cracks here and there in other parts of the ceiling both upstairs and downstairs. So I will continue to use it throughout the house.
In the bedrooms I used 50:50 emulsion/water primer. Now, (dont laff people) wasnt sure whether to use the Polycell in the primer mix or some cheap, no-frills emulsion. The latter option would have saved me a few pennies no doubt. Decided to use the Polycell in the mix in the end, on the basis that it would adhere better and do a better job (no cracks in future) to the ordinary emulsion water-downed stuff. Now is this totally flawed logic on my part? Can I get away with using the cheap stuff in the primer?
Also when applying the above primer, found it going off very quickly on the ceilings. Poss a good thing as I then apply the next coat?
I just happen to have a large PVA bottle lying aroud that was purchased only recently. Was thinking of using this, also I find mixing this stuff up and working with it less hassle than watering down emulsion. I find it easier to produce a smooth, lump free PVA mix than emulsion.
Just had a guy wallpaper the bedroom wall. He's a professional decorator and it was he who suggested the PVA option. So now, im confused ! Is the emulsion based primer better than the PVA mix or is it just people's preferences? Are both methods equally valid?
By the way, I applied a further two coats to the bedroom ceilings after the primer, and they look the dog's dangly bits. icon_cool.gif
Pressure is on. The site manager/project manager/supervisor is hassling me to get the job finished as soon as. And If I dont she's refusing to cook any more meals for me!
Cheers,
Taz
Back to top
 Alert Moderators
Panjandrum
from United Kingdom
PostPosted: Tue Feb 22, 2005 9:16 am Reply with quote
Taz,
My preference for PVA comes from experience with an old house (1896) with external rendered walls and some dubious bits of lath and plaster inside.
Inside and out I like a thin PVA coat on any untreated bits to give a good grip for the paint.
Externally I wash and brush down then PVA everywhere before painting. It's really quick. Lasts a good 8 years outside - re-painted when the designer says so. Next door, same house, gets re-painted every three because their paint is flaking off.
That might be the difference between primer and sealer? Primer preps the surface for painting; sealer does that and also stops helps the paint cling on? Or maybe that's just rubbish.
Back to top
 Alert Moderators
from United Kingdom
Thanked: 1 time
PostPosted: Thu Feb 24, 2005 11:42 pm Reply with quote
Taz m8 you got me confused now icon_confused.gif How do u manage to get a lumpy mix with water/emulsion icon_question.gif Has it been in freezer icon_question.gif
I never use pva on bare plaster and been doin it like that for last 30yrs
Use normal emulsion (matt) for primer, finish with crack free if you want but this takes 24hrs between coats to dry if you put it on thick as it says on can. Has to be thick to achieve thick flexible film.
godd luck.
Back to top
 Alert Moderators
SteveOfKemble
from United Kingdom
PostPosted: Wed Sep 09, 2009 12:54 pm Reply with quote
WARNING: I recently sealed a bare wall before applying Crown emulsion, as advised to do on the can, but I used PVA, as I have always done. Take the advise of "confidentincompetent" and use dilute emulsion.
What happened to me was that when using a roller to apply it, it kept forming little bubbles which stayed until it dried. I now have to rub it down again and apply a second coat. When I suggested to Crown that they warn against this, they refused and placed the blame on PVA.
I have not tried the same with Dulux.
Back to top
 Alert Moderators
francspencer
from United Kingdom
PostPosted: Wed Sep 09, 2009 1:06 pm Reply with quote
water down matt emulsion 50/50 for 1st coat.
Back to top
 Alert Moderators
Robbie uk
from United Kingdom
Thanked: 182 times
PostPosted: Wed Sep 09, 2009 2:08 pm Reply with quote
DO NOT USE PVA AS A SEALER BEFORE EMULSION !!!!
Dilute emeulsion is all that is needed.
Back to top
 Alert Moderators
LJW61
from United Kingdom
Thanked: 63 times
PostPosted: Wed Sep 09, 2009 5:38 pm Reply with quote
As Robbie says ..PVA a no-no !
As for the thinning, I dilute 25-35% water
Back to top
 Alert Moderators
igiveitup
from United Kingdom
PostPosted: Fri Dec 16, 2011 10:50 pm Reply with quote
I have foolishly gone and used PVA as a sealer on the ceiling, and having major problems getting the emulsion to cover, as it's very patchy. Have sanded it tried again, and just sanded it again.
Now there are patches of bare plaster, patches of feint white with pink plaster showing through and just one big ugly mess.
Can anyone please help how to make this good other than lining the newly plastered ceiling?
Help would be much appreciated
Back to top
 Alert Moderators
LJW61
from United Kingdom
Thanked: 63 times
PostPosted: Sun Dec 18, 2011 8:05 pm Reply with quote
Just paint the whole ceiling with an solvent/oil-based undercoat , thin it slightly and apply with a foam/sponge roller & it will seal itb ready for a few coats of vinyl matt..Buy trade emulsion, not Wickes,B&Q etc.
Back to top
The following user says thank you to LJW61 for this useful post:
igiveitup (19 Dec 2011)
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
Primer/sealer for the Walls - went wrong (( help asap needed 4 140 Fri Mar 30, 2012 12:33 pm
water based primer/sealer over knotting solution 2 280 Wed Apr 06, 2011 3:37 pm
Forgot to use knot sealer or primer. 6 260 Sun Jul 27, 2014 8:27 am
painting emulsion over plaster sealer 3 360 Tue Jul 13, 2010 9:08 pm
gyproc dry wall sealer 2 640 Sun Apr 12, 2009 11:17 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
