I've come accross a number of radiators in a property all of which are water filled but are not connected to any water supply. The rads are trendy designer style panel ones and have electrical elements in vary in voltage and wattage as do the size of the rads. Some of the rads can be bled as with a normal wet central heating system, I assume this is just convection from the water being heated inside. A couple are producing no water at all.
I assume the problem isn't the elements (which is why I thought of posting here and not in the electrical forum) as four rads are having the same problem getting only warm. I think it's something to do with the water inside.
I've a fair idea of how these things work but do they need to fill them how do you fill them and what could the problem be??
Any help would be much appreciated.
Cheers
Brian
Cheers
Brian
