DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Is this a fair quote for fitting rads and Magna Clean?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
northcoombes
from United Kingdom
PostPosted: Thu Feb 25, 2010 6:13 pm Reply with quote
Hi all
We need some work done and have received the following quote. Our combi boiler is a year old and all our existing radiators are new (except one) and work very well.
Drain heating installation.
Install Magna-Clean heating component to directly below the combination boiler area
Install 1 radiator to bedroom. (existing radiator needs to move along about half a metre along the same wall - will need to lift floorboards but new floor going over the floorboards so no need to make it look good).
Install 1 radiator to box-room. Pipe-work already in place.
Install 1 radiator to spare bedroom.Pipework already in place
Fill, flush and test all works undertaken. Add protective inhibitor solution on completion.
For The Sum of: 415.00 +vat
Is this a good quote?
Many thanks
Back to top
 Alert Moderators
Geegas
from United Kingdom
Thanked: 46 times
PostPosted: Thu Feb 25, 2010 6:33 pm Reply with quote
Are they supplying the new rads?
Back to top
 Alert Moderators
tamz
from United Kingdom
Thanked: 276 times
PostPosted: Thu Feb 25, 2010 6:44 pm Reply with quote
Sounds fair enough to me if they are supplying.
Back to top
 Alert Moderators
dextrous
from United Kingdom
Thanked: 194 times
PostPosted: Thu Feb 25, 2010 6:48 pm Reply with quote
Sounds a bit like 145 for the magnaclean/inhibitor (supplied and fitted) and 90 per rad. Not too far off the mark to be honest.
Back to top
 Alert Moderators
northcoombes
from United Kingdom
PostPosted: Thu Feb 25, 2010 6:50 pm Reply with quote
Sorry I should have mentioned that we are supplying the radiators, the thermostaic valves and the Magna Clean.
Back to top
 Alert Moderators
heatingman
from United Kingdom
Thanked: 112 times
PostPosted: Thu Feb 25, 2010 7:06 pm Reply with quote
If your supplying the bits, I'd start looking for another quote. That does sound over the top. I can't see the job but sounds like a days easy work. Are the rads huge, is your house huge?
Back to top
 Alert Moderators
northcoombes
from United Kingdom
PostPosted: Thu Feb 25, 2010 7:13 pm Reply with quote
No, it's an extended 1930s semi-detached. We took the radiator out of the back room as after the extension the room shape had changed and we can use a smaller one (600 x 700) which we bought. We are therefore moving the bigger one which we bought about two years ago to the front bedroom (same size as the one there now so it just gets fitted onto the existing pipes).
The third one is in our box room and the new piping was put in place during our extension build but the plumber at the time said he would fit the radiator when he did the other jobs.
We have paid 90 to have a radiator fitted with another plumber last year and he quoted us 70 to fit our Magna Clean but I wasn't sure if the draining down and power flush was the thing costing the money. We did have a power flush and the inhibitor added when they fitted the new boiler last year.
Back to top
 Alert Moderators
northcoombes
from United Kingdom
PostPosted: Thu Feb 25, 2010 7:14 pm Reply with quote
Back to top
 Alert Moderators
rob251
from Ireland
Thanked: 1 time
PostPosted: Thu Feb 25, 2010 8:39 pm Reply with quote
i think that is a fair price
Back to top
 Alert Moderators
Happyplumber
from United Kingdom
Thanked: 706 times
PostPosted: Thu Feb 25, 2010 8:41 pm Reply with quote
I think this job is more like around the 300 to 350 mark for labour only,as you are supplying all materials
We would have this sort of work done in 6 to 7 hours max ,I am also based in berkshire icon_biggrin.gif icon_biggrin.gif
Back to top
 Alert Moderators
sooey
from United Kingdom
Thanked: 569 times
PostPosted: Thu Feb 25, 2010 9:01 pm Reply with quote
You didn't mention that in your first post.
Back to top
 Alert Moderators
northcoombes
from United Kingdom
PostPosted: Thu Feb 25, 2010 10:48 pm Reply with quote
Just went back to check the quote and the exact words are as mentioned in my OP "Fill, flush and test all works undertaken. Add protective inhibitor solution on completion." I just assumed a flush was a power flush - apologies - not very au fait with these terms icon_redface.gif
Back to top
 Alert Moderators
Happyplumber
from United Kingdom
Thanked: 706 times
PostPosted: Thu Feb 25, 2010 11:56 pm Reply with quote
I understood a powerflush was not included in that,it fairly obvious dont worry
Back to top
The following user says thank you to Happyplumber for this useful post:
northcoombes (26 Feb 2010)
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
British Gas Magna Clean quote 48 4980 Thu Jan 21, 2010 11:35 am
Magna clean - is it required for a totally new system? 16 2160 Fri Nov 07, 2008 3:27 pm
magna clean 20 16440 Tue Jun 05, 2007 6:50 am
Magna Clean 'and' Fernox? 3 100 Wed Mar 21, 2012 1:27 pm
Magna Clean Valves Arrrrrrrgh 5 1160 Wed Feb 11, 2009 4:44 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
