DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Stuck tap cover
This topic originated from the How to page called Replacing a washer in a tap
Click here to return to the page called Replacing a washer in a tap.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
diy_chris
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 22, 2005 2:31 pm    Post Subject:
Stuck tap cover
Reply with quote Thanks
On my dripping tap the metal cover you refer to above is stuck.
It is completely smooth, so there is no way to get any purchase to undo it with a tool (I also do not want to damage it).
I have tried applying WD40, but this has not helped.
Do you have any suggestions to help me remove this cover?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
kevplumb
from United States of America
Thanked: 400 times
PostPosted: Tue Feb 22, 2005 3:15 pm    Post Subject:
i take it you are referring to an (easy clean ) cover
water pump pliers if its stuck
or a rubber strap wrench
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
SUPRIMA BOARD £180 INC FITTING AND 1YR COVER ON SYSTEM 13 780 Sun Feb 11, 2007 2:25 pm
Filler to cover hole in bath 2 202 Fri Mar 23, 2007 8:21 am
SEWER COVER 2 2600 Tue Jan 30, 2007 3:54 pm
Removing inspection chamber/rodding point cover. 6 680 Mon Oct 30, 2006 12:51 am
Homeserve Burst Pipe Cover 9 1660 Wed Jul 12, 2006 8:45 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
