hounslowluddite
Joined: 27 Feb 2010 Posts: 4 Location: United Kingdom
Posted: Sat Feb 27, 2010 12:37 pm |
Hi there all.
Any gas engineers out there in this community? I have a puzzling problem with the above appliance.
It has (following a visit from British Gas!) started run the central heating when the time clock says it should be off, and vice versa.
The manual I have has no detailed instructions on the operation of the timer, whch has a 3 position switch in its centre and a clock like hand that alters the position of the timer. Does anyone have a detailed knowledge of the operation of the timer on these apliances? Or is there an over ride switch on this thing that is not on view on the control panel? Or does anyone have a web address where I can get more instruction on this timer?
I'd like to have a go at getting it sorted out before calling BG, as they will try to sting me for another £50 call out charge for sure and I need to avoid that at all costs.
Thanks for your advice |
Agile
Joined: 26 Jun 2004 Posts: 46007 Location: London, United Kingdom Thanked: 2523 times
Posted: Sat Feb 27, 2010 1:45 pm |
If what you have said is correct then they have disconnected the timer and reconnected it wrongly.
Just set it on when you want it off and vise versa.
Tony |
