Replacing radiators - numerous problems
30 Dec 2007
Glasgow
Looking to replace a radiator, but I'm unable to find the drain valve on the system - there was nothing on the pipes in the vicinity of the boiler, and the rest of the pipework is under the floors. Question number 1: Could the drain valve be on the boiler itself? See pic:
This is above the pipes which are under the floorboards, so even if this was the drain valve, would I be able to fully drain the system using it?
Anyway having turned off the flow to the feeder/expansion tank, I think I've managed to drain the system (or at least the radiators) through the hole in the radiator (the reason it's being replaced), which I've now removed and am looking for a replacement for it. Question is, if the radiator I find is of a slightly different size to the old one, is adjusting the surrounding pipework going to be a big problem?
The old one is a modern one but I want an old column style one as a replacement.
Thanks in advance for any help
erm is that pick of boiler please zoom out a bit first so i can see if i can give u advice
The pic is indeed the boiler; what I think is the drain valve is on the mid left, as seen here (not the best pic admittedly, I'll replace it in daylight):
I believe the radiator is cast iron, under a good few coats of thick paint though. Not sure why that matters?
i wouldn't put a spanner any where near that boiler. if the holed rad has drained out you've probably drained most of the system to that level
anyway, almost certainly enough to take the rad off to change it. have a load of rags and a bucket ready, just in case...
you did open the bleed valves on the other rads to drain down, i presume?
good luck
good luck
Cheers. I did open the bleed valves yeah. Radiator is now removed, awaiting a new one in it's place. Now I'm just wondering the practicalities of installing one of a slightly different size; I'm not too sure about fiddling with the feed pipes under the floor - there's not too much slack on the bits that protrude out from the floor (can't mind their names - feed and drain?). Anyway is it an easy job, or should I make a bigger effort to buy same-size radiator(s)?
is it an easy job??
that depends on how good your plumbing skills are, jimmy.
i can't see what's required, so i can't say
