dodgy wiring
19 Oct 2009
London
Had to fit a new consumer for a client, in kithcen boiler was not on spur but feeding off another socket using trunking, i removed the scoket to find wires behind there taped up, measure them using meter and found that neutral was missing, had to look under the floor for the lovely work done by last electrician or so called electrician.
See pictures for results
Dodgy wirring broken neutral and branch
View media item 20288
Dodgy wirring broken neutral and branch close up
View media item 20289
Earth wire
View media item 20290
Earth wire
View media item 20291
lmao
yes you could be right as wiring was run next to pipes, replaced wire with new 2.5mm all working sweet now.
