DIYnot
Local | Network
   DIYnot > Forums
Local | Network
toilet cistern fixing bolts and washers????????
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
kingccc
from United Kingdom
PostPosted: Thu Mar 04, 2010 9:54 pm Reply with quote
hey everybody
i have a push button flush bog and its leaking through the fixing bolts so obviously the rubber conical washers have failed has any of you had this problem and how did you remedy it and also where can i get new parts (bolts and washers) from as upto now i cant find them anywhere icon_confused.gif
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Thu Mar 04, 2010 10:08 pm Reply with quote
that idea is the stupidest idea i've seen
better with the ones that secure to the fixing plates.
either fit new rubbers/bolts or where the bolt comes through the cistern
fill it with clear silicone then tighten the bolts up and re-fit to pan.
Back to top
 Alert Moderators
kingccc
from United Kingdom
PostPosted: Fri Mar 05, 2010 7:27 pm Reply with quote
whats the stupidest idea you have seen?
Back to top
 Alert Moderators
kingccc
from United Kingdom
PostPosted: Fri Mar 05, 2010 7:33 pm Reply with quote
it was fitted to the letter of manufacturers like this in steps 5,6,7,8
http://www.diydoctor.org.uk/projects/fittoilet.htmi just find it hard to beleive that these rubber washers and bolts are unobtainable icon_eek.gif
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Fri Mar 05, 2010 7:47 pm Reply with quote
the cisterns where the bolts come through the base.
best ones are the ones that fix to the securing plate.
yes they are available.
Back to top
 Alert Moderators
kingccc
from United Kingdom
PostPosted: Fri Mar 05, 2010 8:08 pm Reply with quote
where from? even plumbcentre dont have them or at least mine doesnt i cant even find them off net
Back to top
 Alert Moderators
squeaky
from United Kingdom
Thanked: 224 times
PostPosted: Fri Mar 05, 2010 8:13 pm Reply with quote
I fitted one a few months back that had no fixings at all. it was held in place by the screws holding the cistern to the wall. Believe it or not, it did actually work.
Back to top
 Alert Moderators
squeaky
from United Kingdom
Thanked: 224 times
PostPosted: Fri Mar 05, 2010 8:15 pm Reply with quote
If you know the manufacturer, try ringing their customer services dept and they may be able to post some to you.
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Fri Mar 05, 2010 8:22 pm Reply with quote
lunns plumbing on the net do them.
and i have brought them somewhere before but not sure where. icon_rolleyes.gif
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2560 times
PostPosted: Fri Mar 05, 2010 8:34 pm Reply with quote
If you can't find them, I use:
6mm stainless studding, A2 stainless penny washers and nuts (nylock are best), plus 6 3/4" tap washers.
So, cut a length of stainless studding, screw a nylock nut on, add a penny washer, then a 3/4" tap washer - pass it through the cistern from above.
Where it comes through, add another tap washer, then a penny washer followed by a nut. Tighten the assembly up - you can add some silicone for good measure, if you like.
Then pass the 2 studs through the pan - add another tap washer, followed by yet another penny washer, and finally the final nut - preferably a wing type.
See?
Cheers
Back to top
 Alert Moderators
kingccc
from United Kingdom
PostPosted: Fri Mar 05, 2010 9:29 pm Reply with quote
thanks guys and burnerman
bloody lunns want 18.93 with delivery the robbing beggers
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Fri Mar 05, 2010 9:33 pm Reply with quote
i never use lunns he is abit over priced.
Back to top
 Alert Moderators
kingccc
from United Kingdom
PostPosted: Tue Mar 09, 2010 4:57 pm Reply with quote
http://www.toiletspares.co.uk/page_29.html#
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Longer fixing bolts for semi-pedestal basin. 3 640 Fri Jan 02, 2009 5:32 pm
New Cistern on Close Coupled Toilet Leaking - Bolts? 18 13880 Thu Apr 15, 2010 10:09 am
Close Coupled Cistern, connecting bolts spinning 6 80 Wed Sep 19, 2012 11:59 am
Leaking cistern bolts 2 40 Thu Dec 06, 2012 3:59 pm
How to reach toilet seat bolts from behind? 2 120 Mon Sep 02, 2013 9:36 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
