DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Soakaway overflow, downpipe fills up.
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Author Message
oliwatts
from United Kingdom
PostPosted: Fri Mar 05, 2010 2:58 pm Reply with quote
Hi Guys,
I have a problem with my downpipe which is causing water to leak onto my brickwork and causing damp.
When it rains heavily the attached soakaway fills up, it appears the seal to the soakaway is to tight (underground) that the downpipe then fills all the way up to the top of the house where the first guttering joins leaks / sprays out and down my upstairs all. icon_redface.gif
So... I modified a downpipe socket (linked) with a hose connector (quite a neat job really with my Dremal) applied it about 18 inches from the ground and attached a hose so excess water escapes down the hose to the bottom of the garden. It mostly works!!! icon_biggrin.gif
B&Q Marley Square Downpipe Socket
Unfortunately the laws of gravity apply. When the downpipe is not full the water flows down as hoped but when it filled up to the connector the water is effectively flowing up from the bottom, in this case the normal downpipe joints down truly work, a bit of sealant hasn't lasted long and it leaks. Now I'm concerned about water around the base of my house.
icon_question.gif Is there some proper kit for dealing with this or something that will give me a proper seal on the downpipe.
I want to do it properly and while cleaning the soakaway is an option is a joint downpipe with next door and the soakaway is not on my land.
Back to top
 Alert Moderators
jono_h
from United Kingdom
Thanked: 16 times
PostPosted: Sat Mar 06, 2010 8:07 am Reply with quote
It might be easier to dig a new soakaway which could go on your land if convenient. Just connect it up to the existing pipework, and leave the existing soakaway where it is.
It's not a horrendous job - perhaps the biggest pain is getting rid of the soil from the hole.
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1278 times
PostPosted: Sat Mar 06, 2010 8:09 am Reply with quote
Dig a hole and bury it.
Back to top
 Alert Moderators
oliwatts
from United Kingdom
PostPosted: Sat Mar 06, 2010 10:16 am Reply with quote
Yeah, i had considered the same thing. The complicating factor is the downpipe is adjoined on a semi-detached and the soakaway is actually in next doors garden. I suppose the a new one could go anywhere.
I'll try and get something a bit more sturdy the bottom seal on the connector. bathroom sealent outdoors was only ever going to be a quick fix. If that failed the maybe a soakaway if the only reasonable alternative.
Do soakaways not just become less effective overtime? I imagine the old out just gets filled up with crap, surely a new one would suffer the same fate?
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 1529 times
PostPosted: Sat Mar 06, 2010 12:07 pm Reply with quote
Soakaways do clog up over the years but you should expect a good 10 years or so of service from a domestic jobby before maintainance or renewal is necessary bear in mind that they should not be built within 5m of a building or road or 2.5m of a boundary.
Back to top
 Alert Moderators
oliwatts
from United Kingdom
PostPosted: Sat Mar 06, 2010 12:47 pm Reply with quote
Thanks Freddy,
Back to top
 Alert Moderators
alittlerespect
from United Kingdom
Thanked: 47 times
PostPosted: Sat Mar 06, 2010 10:19 pm Reply with quote
Hi!
You may want to consider adapting the downpipe - Dig out around the junction of the downpipe and soakaway connection to expose pipework, temporarily remove downpipe section and construct/connect in a 'back inlet gulley' (big) to the soakaway connection, then shorten downpipe so that it just enters the top of the cover to the back inlet gulley and replace same. Now when the problem occurs the back inlet gulley will flood and you will not have your problem, you may wish to consider replacing the section of pipe as it is now damaged.
Or on the assumption that the downpipe already goes into a 'big' (as it should do, damn unusual to have the downpipe running below ground - never known it myself!) anyway I digress, clean out the trap, which will block up from time to time!
Regards
Back to top
The following user says thank you to alittlerespect for this useful post:
Nige F (7 Mar 2010)
 Alert Moderators
Nige F
from United Kingdom
Thanked: 861 times
PostPosted: Sun Mar 07, 2010 6:13 pm Reply with quote
If you know where the existing soakaway is next door - and it`s near the boundary with you- dig yours near to it and get a 1.+1/2 size one icon_idea.gif allowing for existing one half blocked icon_wink.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
gutter overflow disaster! 5 920 Thu Aug 06, 2009 8:18 pm
gutter overflow problem 4 3000 Wed Aug 22, 2007 8:31 am
dormer runoff leading to lower gutter overflow 11 1040 Mon Sep 21, 2009 12:25 pm
Gutter overflow trough in attic. 35 640 Sat Jan 03, 2015 3:11 pm
soakaway ideas? 2 960 Fri Sep 16, 2005 6:12 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
