Door Closers - Office Partition Walls
19 May 2006
I've been asked to fit some door closers in an office. Two aren't going to be a problem as I can use standard units into the timber frames. However two doors are fitted into partition walls, so I've only got a thin metal frame, and what looks like compressed 'cardboard' panels to fix to.
I can't see that I'm going to get a Perko to fit, a standard closer might work if it lines up with the metal frame, or I fix through the partition with a plate on the other side. Anyone got an suggestions as to what might fit?
Ta,
