DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Cooker switches off as soon as grill or oven used.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
jem16
from United Kingdom
PostPosted: Sun Mar 07, 2010 12:05 pm Reply with quote
My son has just phoned to say that his Zanussi oven ( around 5 years old) is switching off as soon as he turns on the oven or grill. It's ok when you just switch on the light part of the oven.
He has said that he switched it off at the socket, took apart the plug to look at it and check the fuse, put it back together without changing fuse and it seems to be working at the moment.
Any ideas what could be the problem?
Back to top
 Alert Moderators
jj4091
from United Kingdom
Thanked: 198 times
PostPosted: Mon Mar 08, 2010 5:56 pm Reply with quote
Has it been installed correctly?
Back to top
 Alert Moderators
jem16
from United Kingdom
PostPosted: Mon Mar 08, 2010 6:07 pm Reply with quote
Yes it's been in place for around 5 years with no problem.
Back to top
 Alert Moderators
jj4091
from United Kingdom
Thanked: 198 times
PostPosted: Tue Mar 09, 2010 8:46 am Reply with quote
Perhaps the socket it is plugged into is starting to fail & the plug pins are not making a a good connection inside the socket. A new socket top would be my first step.
Back to top
 Alert Moderators
jem16
from United Kingdom
PostPosted: Tue Mar 09, 2010 12:53 pm Reply with quote
Ok thanks. Shall look into that first if it continues to be a problem.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1432 times
PostPosted: Tue Mar 09, 2010 1:44 pm Reply with quote
I suspect that a loose connection has, over time, overheated and is now burned away to a whisker. It might be in the plug or the socket or the consumer unit. If there is a junction box that may well be where the fault is.
If the socket is on a ring, it is more likely in the socket, especially if the plug is a factory fitted one and the cable connection at the oven is a factory fitted block.
When you say "oven" and that it is on a plug, I presume it is a single built-in oven, not a cooker or a double oven.
Back to top
 Alert Moderators
jem16
from United Kingdom
PostPosted: Tue Mar 09, 2010 1:50 pm Reply with quote
Socket has a separate circuit breaker in fuse box.
My son said he opened the plug to check the wiring and fuse so I assume it's not a factory fitted plug as they are usually moulded. He said wiring looked fine and did not change the fuse. When switched back on the grill worked and he was able to cook his sausages.
It's a single built-in oven which has oven and grill.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Cooker hood switches 2 60 Fri Jan 16, 2015 8:40 pm
Baumatic BT82.1GL cooker hood switches 3 360 Tue May 31, 2011 7:31 pm
switches for el. oven & ceramic hob 4 660 Wed May 28, 2008 10:50 pm
Fridge Freezer rarely switches off. Thermostat problem? 7 1420 Wed Oct 17, 2007 6:05 pm
Sink incinerator and wall switches 3 120 Wed Jul 16, 2014 11:51 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
