Forgive me if this sounds daft, but here goes
Due to a burst water pipe under a concrete floor I have decided to re run the pipes above floor level. The problem I have is that the pipes now run in front of the step inside the back door, I need to extend the step over the pipes. I have covered the pipes with some metal channeling and intend to concrete over this to extend the step. Should I add PVA into the Cement mix to help this new bit bond to the original floor? I have done a rough diagram below to try and explane this
