DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Building control re: partition wall in garage
Post new topic   Reply to topic    DIYnot.com Forum Index > Building Regulations and Planning Permission
Author Message
RRRRRR
from United Kingdom
Thanked: 2 times
PostPosted: Thu Mar 11, 2010 6:10 pm Reply with quote
Hi- I'm knocking kitchen into garage, but want to retain an area in the garage for storage before I reach the garage doors (which are staying). Anyone know if I can I partition wall this bit off, with a door, without adding a window/ insulation etc. inside the storage area. Can't find any specific regs. Thanks.
Back to top
 Alert Moderators
stem
from United Kingdom
Thanked: 207 times
PostPosted: Fri Mar 12, 2010 8:57 am Reply with quote
Part L of the building regulations deals with preventing heat loss.
My understanding would be that the area behind the garage doors, which I assume are not draughtproofed or insulated and possibly has single uninsulated walls, would need an external door (double glazed and draughtproofed) between it and the living accomodation. Also the partition wall would need to be insulated as if it were an external wall too.
This certainly applies to the walls between conservatories and habitable rooms, which because they do not meet the thermal requirements, the rest of the house has to be insulated from them.
A quick telephone call to your LABC would confirm.
There are also requirements to prevent the spread of fire between a garage and dwelling, but maybe that wouldn't apply once it's not big enough to get a car in.
Back to top
The following user says thank you to stem for this useful post:
RRRRRR (12 Mar 2010)
 Alert Moderators
Nickam
from United Kingdom
Thanked: 5 times
PostPosted: Fri Mar 12, 2010 10:00 am Reply with quote
Hello R,
I did exactly that with my own house apart from knocking through from the kitchen. I already had a rear door from the kitchen into the garage so I just put up an insulated timber stud wall about half way down the garage, put in a timber suspended floor and now use half the garage a a utility. I did though have drainage already in the garage which helped with plumbing washing machine. I installed a fan with a humidistat for ventilation.
Back to top
The following user says thank you to Nickam for this useful post:
 Alert Moderators
sharma992
from United Kingdom
PostPosted: Wed Sep 01, 2010 9:37 am Reply with quote
Make sure the garage doors insulation is rated, last thing you want is the room to be cold icon_smile.gif
Back to top
 Alert Moderators
DOHdesigns
from United Kingdom
Thanked: 171 times
PostPosted: Wed Sep 01, 2010 9:49 am Reply with quote
A six month old thread...
Back to top
The following user says thank you to DOHdesigns for this useful post:
RRRRRR (3 Sep 2010)
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building Regulations and Planning Permission All times are GMT
Page 1 of 1
Jump to:
Partition wall in garage for utility 3 1140 Thu Dec 09, 2010 1:18 pm
Internal partition wall regs? 2 140 Mon Mar 19, 2012 12:15 pm
Create a vestibule with partition wall - planning? 2 140 Wed Dec 22, 2010 10:18 pm
partition wall in bedroom sharing a window? 4 180 Thu Jul 05, 2012 1:03 pm
moving stud wall partition between floor joists 6 280 Sat Jun 02, 2012 11:46 pm
DIYnot
