Glow worm compact 100e Pump question?
18 Oct 2008
Lancashire
I need to remove the built in pump housing external cover ( 4 Allen screws)! :(
Will any new seals be required on refitting? Or is it generally o.k.
Regards
no the seal is ok to reuse, if your fitting a new pump, the new one comes with a new seal.
Thanks,
Not fitting new pump, just taking front off ( 4 allen screws ) to clean and replacing?
Cheers for that. Fill my boots with what? water?. No seriously I appreciate reply. Is there already an O ring seal there when the pump is split in half?
Regards
picasso already answered your question...remove, do whatever your gonna do with it then re fit..
