DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Joist hangers
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
marsaday
from United Kingdom
Thanked: 8 times
PostPosted: Sun Mar 21, 2010 6:04 pm Reply with quote
I have spoken about this before, but want some opinions if possible.
I will be making a new floor in the attic and will be using the party and gable walls to build off. the engineer says it is much better to use masonry joist hangers, rather than using a timber wall plate bolted to it. it will be much stronger if i do individual bolted hangers to the wall. Slower, but stronger. i am not bothered by time and want to do what is the best for my floor.
Is it better to use individual joist hangers bolted independently or is a wall plate just as good?
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1322 times
PostPosted: Sun Mar 21, 2010 6:18 pm Reply with quote
Your architect may be referring tom the build-in type, possibly?
Back to top
 Alert Moderators
marsaday
from United Kingdom
Thanked: 8 times
PostPosted: Sun Mar 21, 2010 6:54 pm Reply with quote
i am not sure really. he just mentioned they bolt to the wall. and if a fixing fails then there are 3 others or more to hold it in place.
Back to top
 Alert Moderators
Deluks
from United Kingdom
Thanked: 326 times
PostPosted: Sun Mar 21, 2010 8:39 pm Reply with quote
I wouldn't have thought that a wall plate would be inferior if done properly. Maybe his just covering himself as you are not a pro and he might be worried that you'd skimp on the fixings or summat?
Bolt a wall plate every 500mm with M16 bolts and fix the joists to it using hangers wrapped over and nailed in and it won't fail. At all.
Back to top
 Alert Moderators
r896neo
from United Kingdom
Thanked: 561 times
PostPosted: Sun Mar 21, 2010 9:05 pm Reply with quote
Back to top
 Alert Moderators
Static
from United Kingdom
Thanked: 168 times
PostPosted: Mon Mar 22, 2010 10:04 am Reply with quote
"the engineer" might be taking some lateral wall support into the joists.. he specify any wall straps?
Back to top
 Alert Moderators
marsaday
from United Kingdom
Thanked: 8 times
PostPosted: Mon Mar 22, 2010 6:34 pm Reply with quote
no wall straps.
Back to top
 Alert Moderators
Static
from United Kingdom
Thanked: 168 times
PostPosted: Wed Mar 24, 2010 9:01 am Reply with quote
marsaday wrote:
no wall straps.
I wouldnt see an issue with using a wall plate, just ensure its properly fixed down with some angle brackets or nail plates (and noggins etc)..
Course its your engineers PI and changing the design should be agreed with him
Back to top
 Alert Moderators
marsaday
from United Kingdom
Thanked: 8 times
PostPosted: Wed Mar 24, 2010 5:41 pm Reply with quote
Static wrote:
marsaday wrote:
no wall straps.
not sure what you mean by the above. are you saying i should add angle brackets to this wall plate ? if so would you do this from below. if so i would struggle as the ceiling joists are in the way.
Back to top
 Alert Moderators
Deluks
from United Kingdom
Thanked: 326 times
PostPosted: Wed Mar 24, 2010 8:14 pm Reply with quote
Wal plate usually means a timber that sits on top of the wall that roof members sit on top of. You are referring to a timber bolted to a wall, often also called wall plate but not quite the same thing. Ledger plate? wall bearer? can't remember if it has a proper name offhand.
Anyway, either will work. Timber plate or hangers bolted in.
Back to top
 Alert Moderators
Static
from United Kingdom
Thanked: 168 times
PostPosted: Thu Mar 25, 2010 9:52 am Reply with quote
As Deluks says i was refering to the wall plate that the ceiling joists probably sit on..
If your bolting a plate to the wall well its more a detailing issue really, if the plate is below the joists it may be visible within the room below unless you have a suspended ceiling, or face fixing the joists which is nice and simple just have to avoid the bolts.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Joist Hangers 3 180 Sat Jun 18, 2011 7:30 pm
Joist hangers and steel beams... 8 1420 Fri Jul 08, 2011 3:48 pm
Correct Joist hoist hangers 5 100 Sat Dec 24, 2011 9:35 am
floor joist hangers, 32 1140 Wed Mar 09, 2011 12:14 pm
Joist hangers 2 260 Sun Sep 12, 2010 9:20 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
