Are you thinking of christmas lights some of which are wired in series?
These stop working if a lamp fails, as there is no longer a return path.
Domestic lighting circuits are wired in parallel. Regardless of the number of blown lamps, there is always (unless in the event of an open circuit fault on the wiring) a return path.
You get a rash.What if you stick your wotsit in a d y k 3?
my analogy explained it perfectly.. where's the problem?
the end of the hosepipe ( live wire ) is the last light. the water pours out of it and into the guttering ( neutral ) then back down the guttering to the spout
if you block the end of the pipe ( ie the last bulb blows ) then all the other holes still let the water out and it still runs into the guttering and down the spout..
The lights are 'tapped' onto the circuit so i suppose if you look at a circuit diagram of a parallel circuit, if one of the bulbs in that circuit blows, the others still light and the live (pos/neg) and neutral are still there regardless
I know im only qualified and all!
What course did you do to become qualified, and when did you do it?
i did a normal apprenticeship
You're a qualified electrician.How does electricity work?
In your lighting circuit i assume they are wired in parallel? how does it still work if a lamp blows and does your electricity flow back through to Neutral
You're a qualified electrician. What kind of qualified electrician asks something like that?yea so even if any of the bulbs do decide to pop, it doesnt have to go through the bulb first to get back to neutral is that correct?
You're a qualified electrician???it just goes through the neutral cable that is connected, and what about the last light in the line how does the neutral get back to the board?
You're a qualified electrician???that what i dont understand how can there be a return path if the bulb has blown doesnt that make the final connection with the return path??
You're a qualified electrician and you do not have, or know where to find, or in fact have never even seen, a diagram of a lighting circuit?Could somebody explain with the aid of a drawing thanks.
You're a qualified electrician???so can somebody please explain this, what if the last bulb is blown hows does the neutral manage to return to neutral if the path is broken because of the last bulb is blown ?
