DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Grohe flush problems
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
crt
from United Kingdom
PostPosted: Mon Feb 28, 2005 10:36 am Reply with quote
Two problems with a recently installed Grohe push flush (concealed cistern):
1. Flush is too short so doesn't wash away what it ought to. Tried moving the polystyrene float higher up but it hasn't made much difference.
2. Now that I've tinkered as above, when the valve shuts the water supply off, it does so such force that it causes the feed pipe to judder noisily.
Any ideas?
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1133 times
PostPosted: Mon Feb 28, 2005 1:33 pm Reply with quote
'Fraid it's the pan's fault , some are bloody hopeless. What make is it? Not an old one meant for the old 9 litre flush is it? (Now 6l)
Back to top
 Alert Moderators
crt
from United Kingdom
PostPosted: Mon Feb 28, 2005 2:55 pm Reply with quote
The pan is new as well (Ideal Standard).
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1133 times
PostPosted: Mon Feb 28, 2005 4:20 pm Reply with quote
Theirs are ok as a rule.
Is there a sharp bend at the back of the pan?
Can you simulate a "better" flush valve, by takingmost of the Grohe one out? Quite often they click apart for servicing, leaving just a hole in the bottom of the cistern. If that works, maybe a differnt valve is the way to go.
Back to top
 Alert Moderators
PEDANTICVINDICTIVEMAN
from Western Sahara
Thanked: 1266 times
PostPosted: Mon Feb 28, 2005 6:12 pm Reply with quote
You probably need to eat a poor diet so you do big heavy pludumpff jobbies, they flush away better than healthy diets where it's all wind and p**s and float around bobbing away through all the half a pint of water we now have to use for flushing, either that or use a bucket.
Try eating lots of greasy pies and chips regularly and little fruit.
Back to top
 Alert Moderators
brumylad
from United Kingdom
Thanked: 2 times
PostPosted: Mon Feb 28, 2005 10:03 pm Reply with quote
on the flushmaster flap valve the volume of the flush can be adjusted by turning the rubber valve. Might be worth checking yours for a similar adjustment.
Back to top
 Alert Moderators
crt
from United Kingdom
PostPosted: Tue Mar 01, 2005 10:35 am Reply with quote
Thanks - where will I find the rubber valve?
Back to top
 Alert Moderators
brumylad
from United Kingdom
Thanked: 2 times
PostPosted: Tue Mar 01, 2005 1:31 pm Reply with quote
If its a flap type valve the rubber valve is about 2" in diameter and sits oner the hole in the bottom of the cistern.
If its a syphon the ignore my post
Back to top
 Alert Moderators
crt
from United Kingdom
PostPosted: Tue Mar 01, 2005 2:20 pm Reply with quote
I'll look and see what I've got.
Thanks.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Cutting flush pipe on Grohe Eau 2 concealed cistern 4 2380 Wed Jan 14, 2009 3:19 pm
Grohe flush 9 1040 Sat May 05, 2007 8:28 pm
grohe push flush (concealed cistern) problem 3 2800 Tue Oct 14, 2008 7:09 am
Grohe Thermostatic mixer temp problems 5 940 Thu Feb 12, 2009 11:03 pm
Grohe shower fittings 4 60 Sun Apr 08, 2012 8:44 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
