DIYnot
Local | Network
   DIYnot > Forums
Local | Network
How do I acheive a 'Fire Rated' Ceiling
Post new topic   Reply to topic    DIYnot.com Forum Index > Building Regulations and Planning Permission
Author Message
glangri2
from United Kingdom
Thanked: 3 times
PostPosted: Thu Mar 25, 2010 10:24 pm Reply with quote
My 2 storey extension will have an integral garage on the ground floor, and 2 bedrooms above it.
Can anyone tell me how I can achieve the necessary fire rating for the ceiling, in material terms?
Strength wise, the wooden joists need to be 146mm min, but I have read on another post that for the fire rating they have to be 195mm min
Is this true?
If so, and I go for 195 joists with 100mm of celotex between then, fitted in the gaps and flush with the top ...............
What flooring to I need for te bedrooms ? 22mm ?
What thickness of plaster board do I need for the garage ceiling?
And if I go for fire rated low energy down lighters, can I run the cables in the 95mm gap between the top of the plasterboard and the bottom side of the insulation?
And do I need to use temp resistant cable?
Sorry for all the questions !
Cheers
Gary
Back to top
 Alert Moderators
kevindgas
from United Kingdom
Thanked: 467 times
PostPosted: Thu Mar 25, 2010 11:01 pm Reply with quote
the bits i can help you on
1. ceiling plasterboard use the foil covered type this has a 30? mins fire resistance
2. if you fit downlighters in it you will need a fire hood for each light
suggest you download building regs document B this has all the fire stuff in it
Back to top
 Alert Moderators
glangri2
from United Kingdom
Thanked: 3 times
PostPosted: Thu Mar 25, 2010 11:06 pm Reply with quote
I was having a look through the regs earlier, and couldn't find the info I needed in simple enough terms .................... mind you I was looking at it at work at lunchtime, so was in a bit of a hurry.
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 1488 times
PostPosted: Fri Mar 26, 2010 12:37 am Reply with quote
1 layer of 15mm fireboard beneath and 22mm t&g flooring (chipboard or plywood (preferably plywood with lots of screws to try and stop the creaking)) above will achieve 1/2 hours fire resistance. Technically speaking the joists should be at least 195mm high, the depth of the joists is derived from fire tests carried out by British Gypsum, Building Control may well accept lesser joists, you will have to ask them.
Or use 1 layer of British Gypsum 12.5mm SoundBloc board instead.
Back to top
The following user says thank you to freddymercurystwin for this useful post:
glangri2 (26 Mar 2010)
 Alert Moderators
tfish
from United Kingdom
Thanked: 6 times
PostPosted: Tue Mar 30, 2010 6:32 pm Reply with quote
either red board or double board with 12.5 norm. you need to go crazy on insulation as well otherwise the cool zone of the garage will be drawn into the over rooms, a very common fault with inbuild garages
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building Regulations and Planning Permission All times are GMT
Page 1 of 1
Jump to:
Fire regs for exposed timber ceiling joists 8 240 Fri Oct 18, 2013 6:02 pm
running a soil stack through a 60 minute fire ceiling 7 860 Tue Feb 23, 2010 9:47 am
Removal of RSJ from ceiling 8 400 Tue Sep 28, 2010 3:53 pm
ceiling insulation 17 700 Mon Oct 04, 2010 10:55 am
Ceiling speaker wire 10 1040 Tue Jul 06, 2010 5:41 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
