jules10111
Joined: 27 Mar 2010 Posts: 2 Location: United Kingdom
Posted: Sat Mar 27, 2010 3:12 pm |
I'm a newbie and struggling a little with this forum thing, im looking for some hints on whats going on with my dishwasher, it fills when left unattended, then it either overflows if ive left the door ajar or when i open the door i get a substantial puddle, any offers????? |
paulc7617
Joined: 07 Feb 2007 Posts: 181 Location: United Kingdom Thanked: 9 times
Posted: Sat Mar 27, 2010 4:03 pm |
I'm no expert,but it maybe syphoning back through the outlet pipe,try lifting it up 6 inches if possible see if this helps.I am sure the experts will be along later to give you the correct advice.Hope this helps. |
| Back to top |
kevindgas
Joined: 28 Mar 2006 Posts: 5562 Location: Southampton, United Kingdom Thanked: 431 times
Posted: Sat Mar 27, 2010 4:19 pm |
paul has probably diagnosed it for you.
the outlet hose should be raised as high as possible.. ideally right up to the underneath of the worktop/sink level then back down into the waste fitting. |
| Back to top |
Leccy758
Joined: 18 May 2008 Posts: 1256 Location: Cornwall, United Kingdom Thanked: 193 times
Posted: Sun Mar 28, 2010 5:41 pm |
If it is not syphoning back you could always try turning off the water supply and leaving it for a day and see if it fills up then, you may have a sticking fill valve (piece of crud preventing it shutting properly) |
| Back to top |
jules10111
Posted: Sun Mar 28, 2010 10:04 pm |
Thank you all, will check it out and feed you back......... |
