Hey All
First of all I'm not an electrician and simply looking for general advice before I head out and seek a pro... I'm ok with general electrical bits and pieces but would prefer to leave anything major to a pro...
OK my issue - I have a single electric oven which packed up last week - When I removed the old oven to measure up for a new one I noticed the following wiring:
1. Electric Hob was wired directly into a spur outlet and connected to a separate circuit to the RCD labelled cooker (no issue so far)
2. The old oven is wired into a normal plug socket and further investigation found that this is wired into the normal socket ring main in the kitchen/flat...
Whilst the old oven was over 3KW in power the new one is a lot lower ie 2.2KW so my question is 3 fold - Is it ok that the original cooker was wired into the normal socket (flat was built c12 years ago)? If so is it ok that this socket is on the normal plug ring main vs separate cooker circuit? If both the above are OK can the new cooker be connected into the original socket once again?
Alternatively if any of the above are wrong, can another spur socket extension be connected to the original hob one (or the original one be replaced with a double one - if there is such a thing) so that both the cooker and Hob can are on the same ring?
Is the alternative option of replacing the plug socket method hard / complex / problematic?
I ask as I'm not flush with cash at the moment and want to understand what should be done and sound knowledgeable when I speak to an electrician so I don't get ripped off / overcharged - Both hob spur and cooker socket are easily accessible so trying to understand the time and cost should anything need to be changed...
Any help / advice gratefully received
Cheers
A
Cheers
A
