Hi there…looking for advise,
I live in a flat maintained by factor. Last month some youngsters broke the entry door system of our building because some tenants living in the block had not called them for a party. The system was totally non functional. This system was later repaired by the factor and the tenants were charged for the same. Now the scene is that I am able to release the door but unable to listen to any ring. When I or my husband press the ring from outside nothing rings inside. Although we are able to speak to each other and release the door. I reported the fault to the factor and they say that as the door entry system is working fine in all the other 8 flats and it is only my flat where it is not ringing then probably there is some fault in my handset. My system was working absolutely fine before this incident. I tried to convince them but to no avail. This is there response:
"I have just checked with the technical officer and she thinks that the door entry system is working okay. I will pass an order to get someone to call out to check your handset - if this is at fault, then you will be responsible and be recharged. The contractor should hopefully be in contact with you this week."
I don’t understand what to do in these circumstances. I am also worried that I might have to spend money unnecessarily. I understand people using this forum are specialist. Please advise.
Regards,
Regards,
