boiler will trips out when heating water
13 Mar 2010
Hertfordshire
Hi all, I'm new to this forum and I'm hoping many of you have come across this before.
I have moved into a new house which has a potterton suprima boiler, I have had problems with air collecting in the rads since i moved in and also 3 of the rads have cold spots,
The header tank in the loft gets hot when the boiler is on and has at leased an 1" of silt in the bottom.
I cleaned the whole system/ header tank/ took every radiator off and wrinsed through etc.
But after refilling the system and bleeding the rads the boiler cuts out when set on hot water, it makes a hell of banging before tripping out.
I have tried bleeding the coil in the tank by undoing the actuator fittings, but its still tripping the boiler.
the boiler is 3 years old but the rest of the system is older.
anyone have any ideas, if i dont get this fixed the wife will devorce me!
When operating in hot water mode the pump is still normally used to circulate the central heating water round a closed loop. Hot water is passed through a heat exchanger.
Success after bleeding more parts from the boiler to the coil in the hot water tank, I found a section of blocked pipe, its now running :)
Thanks all.
