DIYnot
Local | Network
   DIYnot > Forums
Local | Network
secrets to laying wire under floorboards
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
Gaz TFA
from United Kingdom
PostPosted: Sun Mar 09, 2003 10:28 pm Reply with quote
is there any secrets, other than riping every other floorboard up, to laying cable from one end of the room to the other ?
obviously i have to choose to go along side joists and not against them! grrr
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sun Mar 09, 2003 11:20 pm Reply with quote
if you maen that the joists are going the same way as the cable then yes there is a way, its called fishing.
You get something long and flexible (i use a piece of trunking) you tape on the cable, (with a loop on it) push the trunking down as far as it will go, go to the other end and put down another piece of trunking with a "hook" on it and fish for the other one then pull it out.
Back to top
 Alert Moderators
Gaz TFA
from United Kingdom
PostPosted: Mon Mar 10, 2003 12:29 am Reply with quote
Back to top
 Alert Moderators
MANDATE
from United Kingdom
Thanked: 129 times
PostPosted: Mon Mar 10, 2003 12:35 am Reply with quote
I appreciate your problem and have two comments
Whist you prefer to go with the joist theres nothing wrong going across,you would need to drill holes (not too large) and at least 50mm below top of joist to avoid nails and cable does not need securing
Going with the joists I have an idea that might just solve the problem.
Can you not have access about every 6 ft and instead of securing the cable to the joist you secure the cable to a wood batten in a slightly different manner and then secure the batten to the joist.
Intead of using clips that hold the cable tight you need a loose ring or maybe "screw in hooks" every 2ft
You can place the batten under the boards and thread the batten on to the cable as you move it to the correct position, then secure the batten (nail/screws),this will ensure you have cable support in areas you can't reach
If you had hooks you could secure the batten first and reach far enough to place the cable on the hooks
I can't see why this method won't work
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Mon Mar 10, 2003 6:14 am Reply with quote
trunking
you can also get it at most major diy stores
Back to top
 Alert Moderators
Gaz TFA
from United Kingdom
PostPosted: Mon Mar 10, 2003 9:53 am Reply with quote
Back to top
 Alert Moderators
amtodd
from United Kingdom
Thanked: 1 time
PostPosted: Mon Mar 10, 2003 1:34 pm Reply with quote
There is a bit more to drilling holes through joists than being 50mm from the top and bottom.
Part 1B6 of the building regs says any hole should be central to the depth of the joist, no more than 25% of the depth of the joist, no closer together than 3 x the diameter of the hole and between 25% and 40% of the length of the span from a supporting end.
For notches there are different rules.
Very few sparks or plumbers bother with any of this as they either don't know any better, or don't exect the client to.
Back to top
 Alert Moderators
Gaz TFA
from United Kingdom
PostPosted: Tue Mar 11, 2003 8:33 am Reply with quote
i used the plastic cover from surface mounted wire leads (as i'll be removing them anyway) and taped them together with tape to form 8 ft of wonderous stiff yet bendy stick with hoop on end, thankyou so much, im kicking myself that i had to ask, thanks for the help guys
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Alarm System - 4 Wire Bellbox ??????? 11 2320 Thu Feb 06, 2003 12:41 pm
Live Wire! 5 1020 Wed Nov 20, 2002 3:22 pm
How do I wire a dimmer switch correctly. 3 1340 Sat Oct 26, 2002 12:30 pm
"live" neutral wire 4 4680 Sat Mar 01, 2003 5:17 am
Earth wire to fuse box 12 7500 Mon Jun 09, 2003 10:37 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
